CRX launch
Old Apr 9, 2004 | 12:04 AM
sunny_dacanay's Avatar
Default CRX launch
Hi,
We got a CRX (stock 1.6L) w/ Jackson Racing Supercharger. The computer has been upgraded with a Zdyne fully programmable EMS. Quater mile time of 12.9. The problem we're having is launch. The CRX has a really short wheelbase and it's also really light. Can't seem to get out of the box without spinning the wheels (Mickey Thompson slicks 24s) alot. Spring rating is 541lbs w/ KYB adjustable shocks. Any advise will be greatly appreciated.
Old Apr 9, 2004 | 04:46 AM
HondaGuy02's Avatar
Banned
Default Re: CRX launch (sunny_dacanay)
tie downs/traction bars ?
do you have any traction bars?
Old Apr 9, 2004 | 04:52 AM
DaveF's Avatar
Default Re: CRX launch (HondaGuy02)
what air pressure are you running in your slicks ?
Old Apr 9, 2004 | 05:18 AM
h22avid's Avatar
Default Re: CRX launch (Dturbocivic)
I agree... Traction bars and lower the air pressure somewhere between 15-20; whatever works best for you and your driving style.
Old Apr 9, 2004 | 05:25 AM
.y2a.'s Avatar
Default Re: CRX launch (h22avid)
would wheelie bars help him?
Old Apr 9, 2004 | 05:27 AM
GTPcrew's Avatar
Don't blame it on the Crx. We got low 1.5's before we switched to the wheelie bars. I could be alot of things. Slick size, the RMP that you launch, Tire pressure, the way you let out the clutch ect.
Old Apr 9, 2004 | 10:57 AM
Boner_Ben's Avatar
Lower the tire pressure alot lower than 15-20 psi! Do like 10-12 psi cold, they will wrinkle and help you hook, and then when they heat up as you go faster, they will "grow" as the pressure increases.
Old Apr 9, 2004 | 11:49 AM
h22avid's Avatar
Default Re: CRX launch (BonerBen)
I only mentioned that as a starting point to start testing and tweaking. And if I'm not mistaken, most drag slicks reccommend no lower than 15 psi. I personally run 13 psi on street tires so I wouldn't be too concerned about dropping below the reccommend pressures on slicks
Old Apr 9, 2004 | 01:13 PM
Boner_Ben's Avatar
On radial tires, too low tire pressure will acctually decrease the amount of traction because the middle of the tire will lose its contact with the ground and you will ride on the sidewalls. Full slicks dont have this problem for the most part. How high are you launching the car? How are you heating them up? If you have enough power, try a 2nd gear burnout so you can burn them longer. No reason a car at that power level shouldnt be hooking up and pulling 1.7's.
Old Apr 13, 2004 | 05:02 AM
ILOVEJAPS's Avatar
I persnally know these guys. They race the SNC SPEED GARAGE CRX. He can't launch the car with the tire pressure being higher than 8<U></U> PSI. Anything higher and he just spins the tire to his 10,000rpm redline. No Lie. His rear seems to be squatting at least 3 inches on the launch. According to them his launch rpm is 5000. Oh, and the tires are huge (24.5 inches) considering this is a stock block b16a. Vtec activation I believe is at 5500 rpm. I believe his best 60 was 1.6 or 1.7, but he only ran 13.0 on the run he did this. His best was 12.9 @ 106.58mph with a 1.95 sec 60 foot. Go figure!!!!
ED9man
Aug 18, 2006 04:25 PM
ham
Nov 17, 2005 10:38 PM
alexsracing
Aug 2, 2005 07:14 AM
jt-sport
Jan 26, 2003 11:12 AM
jt-sport
Jan 25, 2003 03:40 PM
