two-step?
Old Apr 13, 2004 | 07:02 PM
v-6 hatch's Avatar
Default two-step?
does any one use a two step rev limiter for draging. is it just anther stupid idea or is worth it ?
j.
Old Apr 13, 2004 | 07:15 PM
L-B racing's Avatar
Default Re: two-step? (v-6 hatch)
definetly a stupid idea. just bang the motor off the rev limiter and drop the hammer
Old Apr 13, 2004 | 07:18 PM
v-6 hatch's Avatar
Default Re: two-step? (L-B racing)
is that why your so quick
Old Apr 13, 2004 | 08:08 PM
99blackcivicSi's Avatar
is this a joke? pretty much everyone uses one
Old Apr 13, 2004 | 10:44 PM
Cyphear's Avatar
They are great. I have one for free from uberdata. You can get consitent launches, build boost (if you have turbo). The consistent launches are good for testing stuff at the track as well as getting good lauches every time.
Old Apr 14, 2004 | 07:20 AM
v-6 hatch's Avatar
Default Re: (Cyphear)
thanks guys i wasn't sure if people used em or not because i want to get one. i did a search and nothing popped up on them so i figured i'd ask.
Old Apr 14, 2004 | 07:38 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: (v-6 hatch)
I do not use one of these 2 step thingies, its just a lie, the box that says 2step is actually a cruise missle weapons controller module... Good Day..
Old Apr 14, 2004 | 08:45 AM
GTPcrew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-B racing &raquo;</TD></TR><TR><TD CLASS="quote">definetly a stupid idea. just bang the motor off the rev limiter and drop the hammer </TD></TR></TABLE>
That one had me falling on the floor. Good one Brent
Old Apr 14, 2004 | 09:54 AM
95GLX's Avatar
I think Brent is just pulling your leg!
definitely a good thing to have. I never had one on my GTi but I was pretty good at keeping the rpm's consistent on the line. At least that is what I always thought. The 2step garauntees that for you and takes away any doubts as to what you may have launched at. This will also let you choose the best launch RPM and basically set it and forget it so you are consistent each and every time. Hold the switch mash the pedal and stage.
Old Apr 14, 2004 | 10:38 AM
Kataku2K3's Avatar
Default Re: (95GLX)
They're definately nice especially when you need to stage fast and want to be consistent. Try lining up on a pro light, setting your rpm, and launching without one. I'm sure it would be a lot more work, hehe
Old Apr 14, 2004 | 06:09 PM
SiR831's Avatar
Default Re: (Kataku2K3)
sorta newbie question.... When the 2 step is activated. Does it make a difference (performance wise) if the throttle is WOT or just enough to bounce of the 2 step rev limiter?
Old Apr 14, 2004 | 06:30 PM
Kataku2K3's Avatar
Default Re: (SiR831)
It's really only used for holding your revs at a specific rpm while you launch. Then you just go to the floor and release the 2-step switch (whatever it may be) when you launch. There's not really any performance gains from it other than on an FI car it'll help you build boost at the line.
Old Apr 14, 2004 | 07:39 PM
v-6 hatch's Avatar
thanks fellows for all that posted seriously.
Old Apr 14, 2004 | 07:51 PM
Cyphear's Avatar
no problem.
sir831: it shouldn't make that big of a diference unless you have a turbo like kataku2k3 said. v-6 hatch, note that with a chipped ECU, and uberdata which is free, you can have an adjustable 2 step.
98silvercivicEX
Jun 30, 2010 07:58 PM
turbo boost
Jun 26, 2008 07:19 PM
Black R
Mar 2, 2005 08:45 PM
TeStUdO
Dec 26, 2003 06:51 PM
turbospool
Jun 17, 2003 01:20 AM
