Lighting HID/Xenon kits, Retrofits and Associated Topics
halos NEED HELP!!
Old Mar 24, 2009 | 09:10 PM
kckchjchfc's Avatar
Default halos NEED HELP!!
i have a 97 civic ex. i bought some halos from someone. no instructions. i know you have to tap into the parking light. but can someone help me to make i do it right. here are some pictures. can you just say take that wire put it there please. thanks i appreciate it.
-walter
Old Mar 25, 2009 | 05:30 PM
kckchjchfc's Avatar
Default Re: halos NEED HELP!!
bump
Old Mar 25, 2009 | 07:59 PM
OTiS515's Avatar
not 100% sure but i think green is actual blinker wire.
Old Mar 25, 2009 | 08:17 PM
kckchjchfc's Avatar
well i tried putting the two reds on the other red but it dint work. how could i test to see if the actual halos work?
Old Mar 25, 2009 | 08:20 PM
19Accord97's Avatar
You can't just put the two positive wires in a positive wire. What did you do with the ground wires from the halos? By only hooking up the positive wires you are not completing the circuit so they will never light.
Old Mar 25, 2009 | 08:22 PM
19Accord97's Avatar
Also, make sure you hook them up to a 5v source or less.
Most LED's max voltage is 3ish volts. Hooking them up to a 12v power source will cause them to burn in in a couple of months.
Red wires w/ red wires. Black wires w/ black wires. (Are those two white wires w/ the circular terminal the ground for the halos?)
Old Mar 26, 2009 | 10:01 AM
kckchjchfc's Avatar
I took the groung and bolted it onto the frame. sanded before.
Old Mar 27, 2009 | 02:20 PM
kckchjchfc's Avatar
help me please
Old Mar 27, 2009 | 08:10 PM
19Accord97's Avatar
So were those white wires the ground?
I see your signal bulb has 3 wires. I am not familiar with Civics lighting, but had halos at one time myself. I am assuming that bulb can be on all the time but is also the turn signal, correct?
If so, you need to make sure you are tapping into the correct power wire, the one that is on constantly. And how are you tapping into the + wires? You really need to splice into them and hardwire them.
Old Mar 28, 2009 | 06:14 AM
kckchjchfc's Avatar
yea they stay on all the time. idk how to find the correct wire. and im not good with electrical. how do i splice and hardwire. i tried googling it but found nothing.
Old Mar 28, 2009 | 01:36 PM
19Accord97's Avatar
The correct way would be to cut the positive wire going to the bulb, and solder the positive wires from the Halos together and then heat shrink them. Then you do the same for the negative side. However, b/c the white wires from the halos (which I am assuming are ground wires) already have a circular terminal, you can just bolt that to and grounded bolt. Just make sure you sand some paint away to get good contact.
Of course, never let the - and + wires touch.
That should be all you need. Solder the + wires to the red wire going to the bulb.
Use the bolt that is on the radiator support bar that holds your headlight in (a small bolt directly above the headlight) , remove bolt, sand the paint away, and then put the terminal on, and replace the bolt.
Old Mar 28, 2009 | 07:52 PM
kckchjchfc's Avatar
ok thank you but the two red wires from the halos were crimped together with a female terminal. so just solder those two together heat shrink to red wire. bolt ground. thanks doesnt sound too hard even tho i went today and took the 2 reds and put them on the battery (+) side and put the ground on the ground side of the battery and nothing happened...
Old Mar 28, 2009 | 09:35 PM
19Accord97's Avatar
Did you turn the key to the on position? I think they still should have lit up.
The halos could be bad.
Can you put some better pictures up of the wiring on the back of the headlights?
Old Mar 28, 2009 | 09:52 PM
kckchjchfc's Avatar
yea ill do it tommorow. its raining and 1:51 here. can you pm me your number. ill talk to you more and i can explain better. and send picutres..
eg6_pink
Apr 16, 2008 07:55 AM
Racermech
May 23, 2005 08:29 AM
ProjectCRXtacy
23
Oct 18, 2004 02:21 PM
