Lighting HID/Xenon kits, Retrofits and Associated Topics
Proper alignment
Old Mar 27, 2009 | 04:21 PM
Partizan's Avatar
Default Proper alignment
I tried aligning my headlights on my 96 coupe and it didn't seem to work. My headlights are oem and I followed the following instructions.
I parked 25 feet away from a wall. Then i measured how high the center of my lights is from the ground. That was 22 inches. Then on the wall i marked a line of 2 inches lower than that so 20 inches. And i aimed it to those specs.
Doing that made the low beans look like highs, and highs cannot even be seen on the road. What gives?
Old Oct 21, 2009 | 09:28 AM
99 TW EJ8's Avatar
Default Re: Proper alignment
Dang, that's lame. Any updates? I'll be trying to align my headlights tonight!
Old Oct 21, 2009 | 12:09 PM
98civdx's Avatar
Master Detailer
i never do the wall thing, its to anyonying, i just park the car on my street, mess with them a little see how the look on the road, and then drive around the block and see how they are, and adjust as needed....
we tried the wall thing with my friends car and the same thing happend, and i dont know how to fix it.
Old Oct 21, 2009 | 03:30 PM
99 TW EJ8's Avatar
My problem is trying to adjust the driver's side headlight. There's too much stuff in the way
The last time I did it, I actually took the bumper off to get the headlights out and adjust as needed. I had it pointed to a wall...but not far enough lol. They looked okay on the wall from the distance I was from it, but then as I backed up, they were all messed up
Old Oct 22, 2009 | 07:04 PM
TunerN00b's Avatar
The ground needs to be completely flat and level to measure on a wall. Any incline or irregularity in the floor will throw all measurements off.
Old Oct 22, 2009 | 10:16 PM
98civdx's Avatar
Master Detailer
grab the power steering res, you should be able to lift it up out of the way,
you the driver side is kind of anyoying to adjust.
OhShift!
May 29, 2011 03:09 AM
Partizan
Sep 14, 2009 08:49 PM
TSAngry
Sep 19, 2004 03:12 AM
WalkmanX
Sep 9, 2001 10:41 AM
