Lighting HID/Xenon kits, Retrofits and Associated Topics
Question on Type-R Fog Light switch
Old Feb 11, 2009 | 01:14 PM
egturbolsvtec's Avatar
Default Question on Type-R Fog Light switch
Basically I have a jdm type-r fog light switch and it stopped working on me one day but the led light still works on it and I was told I need a relay on it somewhere and the switch burned up cause i didnt have one is that true if so what type of relay do I need and where does it go. If any one has had this problem or knows anything about it please let me know, thankyou.
Old Feb 15, 2009 | 02:01 PM
Default Re: Question on Type-R Fog Light switch
anyone
Old Feb 15, 2009 | 02:30 PM
Spids5's Avatar
Don't judge or question
Running your fogs without a relay is a bad idea. Do it right and you won't have this problem. Here is my write up so you can fix your problem.
https://honda-tech.com/forums/lighting-107/how-jdm-itr-hid-headlight-fog-light-wiring-2195061/
Old Feb 15, 2009 | 06:53 PM
Hey thanks man i really appriciate the help
Old Feb 21, 2009 | 01:58 PM
chinkyx90's Avatar
whats so bad to do it without a relay?
Old Feb 21, 2009 | 02:12 PM
Spids5's Avatar
I don't know how many amps the switch can handle but I'm sure it is a lot less than the relay. By not using a relay you are running the power through the switch instead of the 30 amp relay which is not a good idea.
Old Feb 21, 2009 | 04:47 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My brother used to burn out switches ALL the time from the 50W driving lamps we mounted on his Ford Ranger. Finally we wised up and wired up a relay and it never burned out another switch again.
4DRmafia
Nov 9, 2006 09:48 PM
street_ride14
Jun 24, 2006 08:15 PM
1989CivicSi
Jun 11, 2006 01:28 PM
GS8HFL21
Nov 9, 2005 06:56 AM
