Lighting HID/Xenon kits, Retrofits and Associated Topics
water in headlights ?!
Old Mar 17, 2009 | 10:29 AM
dizbjazon's Avatar
Default water in headlights ?!
there is water in my headlights. anyone know how to make it come out?
Old Mar 17, 2009 | 12:32 PM
TunerN00b's Avatar
Default Re: water in headlights ?!
Verify that the little drain tube in the back is clear, to allow the moisture to escape, and turn on headlights and highbeams for 15 minutes.
If you really want it all out, again, clear the drain tube, remove bulbs from lamps, remove lamps from car, pour some rubbing alcohol into lamp and swish around, drain alcohol out the drain tube, and reinstall in car.
Its generally a clogged drain tube that allows the moisture to build up. Mine have never had visible water in them (DC2), even the morning after an all night rain.
Old Mar 17, 2009 | 07:03 PM
ScottyTuned's Avatar
Like said above, check that. Make sure the lights are fully sealed too, to make sure no more gets in and burns out your bulbs.
dc2long
Jan 24, 2009 04:14 PM
K i l l a B e e.
Aug 7, 2007 08:48 PM
drumminforev
Oct 10, 2006 07:02 PM
B00STeD
Feb 21, 2003 04:37 AM
USDM 4G VTEC
Jun 17, 2002 02:39 PM
