Lighting HID/Xenon kits, Retrofits and Associated Topics
Fog lights!!!driving me nuts!!!
Old Feb 7, 2009 | 09:52 PM
88 EF Hatch's Avatar
Default Fog lights!!!driving me nuts!!!
OK I HAVE A QUESTION. I GOT 89 PRELUDE FOGLIGHTS ON MY 88 EF HATCH. YOU KNOW THE CHEAPEST AND MOST AVAILABLE ROUTE TO GO IF YOU ARE TRYING TO HAVE A JDM LOOK WITHOUT CONVERTING THE FRONT END. ANY WAYS I HAD TO CUT THE BUMPER AND MOUNT THE LIGHTS AND EVERYTHING. MY FOG LIGHTS HIGHER THAN MY HEAD LIGHTS. WHEN IM DRIVING ON THE FREEWAY THE SIGNS UP TOP THAT TELL YOU EXITS ARE YELLOW. ARE FOGLIGHTS SUPPOSED TO SHINE HIGHER THAN HEADLIGHTS? ARE THEY SUPPOSED TO SHINE TOWARD THE GROUND? OR ARE THEY SUPPOSED TO SHINE STRAIGHT AHEAD? OR EXACTLY WHERE HEADLIGHTS SHINE? HERE ARE SOME PICS OF THE CAR. IF YOU LOOK CLOSE ENOUGH, THE LIGHT ON THE CURB IS BLUE AND THE YELLOW FADES OFF INSTANTLY. HEADLIGHTS ARE 30K HID AND FOGS ARE 3K HID
Old Feb 7, 2009 | 10:02 PM
CarbonizedDX's Avatar
Default Re: Fog lights!!!driving me nuts!!!
There should be an adjustment screw or way to slide the top of the assembly forwards to tip the light downwards. Not knowing how you did the modification I can't say what to do, might be the housings are upside down...
Old Feb 7, 2009 | 10:06 PM
so then should foglights be pointing down or at the same level with the headlights?
Old Feb 7, 2009 | 10:07 PM
Old Feb 7, 2009 | 10:08 PM
Old Feb 7, 2009 | 10:16 PM
and foglights are not upside down.
Old Feb 8, 2009 | 05:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Do not type in all caps. I'm not even going to try to read that first post.
Edit your original post with normal type so we can all read it and give you an informed answer.
Old Feb 8, 2009 | 09:20 AM
Devon M's Avatar
Fogs shouldn't be in the air like that, but then again you do have HID fogs so... But they should be from the ground up to about where your headlights start and then wider than your headlights. Your HID's are blinding the world!
Old Feb 8, 2009 | 10:05 AM
if they are aimed up then yes you need to aim them down to sit below the headlights, they are not ment as driving lights but as extra light or light in fog conditions.
skalleluia909
Lighting
Aug 20, 2008 06:26 PM
radio1global
Feb 20, 2007 01:43 PM
Rostr02
Oct 8, 2004 10:34 PM
matman4444
Jul 14, 2004 08:19 PM
