Lighting HID/Xenon kits, Retrofits and Associated Topics
will my HID's work for a jdm front end conversion?
Old Mar 8, 2009 | 10:38 PM
<3 v-tech's Avatar
Default will my HID's work for a jdm front end conversion?
i have a 01 integra gsr with HID's and i was planing on doing a jdm front end conversion. my question is, would my HID's still work with the jdm front end conversion or will i have to replace them and get new ones for the new head lights?
Old Mar 9, 2009 | 06:25 AM
operatic's Avatar
Default Re: will my HID's work for a jdm front end conversion?
If you have a non-HID JDM front end you're old HID kit will work. If not you'll just need to pick up a pair of D2S bulbs and D2S to Amp connectors to make your old kit work.
Old Mar 10, 2009 | 11:47 AM
<3 v-tech's Avatar
thanks for the help
Old Mar 10, 2009 | 12:59 PM
denshu's Avatar
Mind you, that you'll be blinding oncoming drivers cause the jdm beam pattern is like this
---\____----\_____
But you need it to be ____/----____/----- if your in the North America
Old Mar 10, 2009 | 01:42 PM
IT'S ME DAVID's Avatar
NooB
how do u go about fixing it reaiming ?
Old Mar 10, 2009 | 02:11 PM
C_Rock77's Avatar
You'll have to pull the lamps apart, and reverse the shields. Flipping the pass one 180 degrees and putting it on the driver's side....same with the driver's side.
The shields are the part of the projector responsible for the shape of the cutoff. If I understand correctly, the shields are removable. So, you should be able to remove them and swap them out.
BARTEG
Jan 31, 2006 08:04 AM
98cwtypeR
Nov 4, 2002 01:46 PM
zRd#1
Oct 21, 2002 02:36 AM
ozzyman
Sep 10, 2002 01:08 PM
