Lighting HID/Xenon kits, Retrofits and Associated Topics
Simple Relay Question (need answer asap)
Old May 10, 2009 | 11:23 AM
OMG THE GOGGLES's Avatar
Default Simple Relay Question (need answer asap)
I am wiring in foglights, OEM ones, and running a 30amp relay direct to the battery. I am getting signal to allow power to the relay via the stock lowbeam wiring, and I need to know something about the switch I am going to use.
The switch will be between the signal to turn the relay on, and the lowbeam wiring. It only supports 12amp (tiny inconspicuous switch). Do I need to get something that will support the 30amp? Or would that only be if I had it going inline with the battery/foglight itself?
I am unsure of the requirements for amperage as far as the switch side goes, when using a relay versus just tapping in direct.
Old May 10, 2009 | 08:35 PM
boynblue's Avatar
Default Re: Simple Relay Question (need answer asap)
You will be ok with that switch and relay. The switch is just to turn the relay thats it. The 30 amp is for the wiring between the battery and lights. You will be good.
menappi
Jan 7, 2007 07:35 AM
NathanielH
May 9, 2006 08:36 PM
GS8HFL21
Nov 9, 2005 06:56 AM
hatchdrvr
Audio / Security / Video
Mar 10, 2003 08:20 PM
Christine
Oct 3, 2001 07:44 AM
