Lighting HID/Xenon kits, Retrofits and Associated Topics
hids
Old Feb 23, 2009 | 06:09 AM
94_4door's Avatar
Default hids
ok ineed sum help if any one knows how to trun off the safty circet on hids cuz the mainal that came with them dosent say and one wont turn on now but woked before and the lampes are good and wireing is good just need to know how to reset it thx for the help
Old Feb 23, 2009 | 08:03 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: hids
huh?
it would help if you used periods, and complete sentences.
i think your having a problem getting your aftermarket HID's to work in your car.. but they worked before installing?
these are REAL HID's? with a ballast and ignitor? not just replacement bulbs.
the headlight circuit doens't have a "reset" button, it only has a regular fuse.
Old Feb 23, 2009 | 11:39 AM
94_4door's Avatar
Default Re: hids
ok it worked after install. then my little brother turned them on and off repededly. now one wont turn on but if u swap the ballast and ignitor the bulb works fine. and the manual states that there is a saftey circet thats active. all i wanted to know is if any one knows how to reset that circet. not for some one to complain cuz i didnt use periods, and complete sentences.
Old Feb 23, 2009 | 11:45 AM
Built B16A's Avatar
Default Re: hids
i complained because i couldn't understand your question.
lemme try and help you now you said you swapped the ballast from left to right and and it worked so there is something wrong with the ballast from my experiences there isn't a reset button on the ballast you can try and open it and see if theres some broken contacts on the circuit board or wires other than that your going to need a new ballast
now hows that for great punctuation. sucks huh?
EJoneuglyhonda
Oct 27, 2013 11:13 PM
slowestek
Lighting
Jul 14, 2011 10:53 PM
kjg8erz8
Aug 1, 2006 11:50 AM
b18bEG
30
Dec 13, 2004 05:26 PM
fe519
Acura TL, RL & ZDX
Dec 18, 2003 02:42 AM
