need help with lights!! they won't turn on!!
I have an integra with 9006 socket lights.
When I plug in a regular bulb the bulb would turn on but when I try installing my hid kit it won't turn on.
There is nothing wrong with the kit because I've tried every ballast bulb and wiring combination that I can think of.
I've check the fuse for the Left Headlight low beam and it seems to be there is no continuity. So what can I do to solve this problem? Help me HT!!
Re: need help with lights!! they won't turn on!!
rotate the plug 180 degrees and try again, most hid kits are wired reverse of standard 9006's and most kits have a secondary tab that the lock arms will hook onto...
CheezeFrog
08-08-2001 03:27 PM
