Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
How do you reset computer for AC system to function
Old Apr 9, 2013 | 12:18 PM
romeo7's Avatar
Default How do you reset computer for AC system to function
How do you reset computer so as allow both fans to work FOR the AC system
Old Apr 9, 2013 | 01:48 PM
redyute's Avatar
Default Re: How do you reset computer for AC system to function
Explain buddy year make model and what ur problem is
Old Apr 9, 2013 | 02:17 PM
romeo7's Avatar
i have a 2006 Honda civic hybrid when i turn on the AC the compressor and fans dosent work however when u bridge the system both fans and compressor work
Old Apr 10, 2013 | 02:07 PM
redyute's Avatar
Last one i had with that problem it turned out to be the switch inside the car,have you confirmed that its good?
Old Apr 24, 2013 | 09:26 PM
bighoss77's Avatar
obviously your not getting power to both the a/c clutch and fan, either you have pressure problems or pressure switch problem, or maybe the relay is bad? could also be switch inside car, but not very common. Check relay first. Then check high pressure switch, or possibly take it to a shop and have them hook some a/c guages up and make sure the system is full or the system as at the right pressure
Old Apr 28, 2013 | 08:56 PM
BurntBisquit763's Avatar
Check for power and grounds!
DaX
Aug 16, 2023 02:31 PM
pudhonda
Jun 10, 2017 11:43 AM
Sketch_hs
Aug 21, 2007 11:38 AM
EJ8 GSR-T
Aug 8, 2007 09:48 PM
emissionsux
Jul 7, 2005 09:43 AM
