civic lx 2009 4dr - constant hum in the speakers
Hi everybody,
It started a few weeks ago, when I put the key into ignition (position I) without starting the engine. It's present with the radio on/off as well but it gets a bit louder when the engine is running.
So far I've replaced the radio but no luck. There are no mods on the car, it's stock.
Last night I drove home very late and I had my lights on (low beams- I haven't driven the car at night in a long time) and I've noticed that the noise is almost gone (fainted). When I turned off the low beams the noise level rose again. I turned on the mirror heating getting the same results.
I can't find any explanation for this...
Any ideas?
Thank you !
Adrian.
Any ideas?
Thank you !
Adrian.
Re: civic lx 2009 4dr - constant hum in the speakers
Have you checked all of your grounds?
Has your alternator been tested?
http://answers.yahoo.com/question/in...8200032AAMVrgL
http://stereotechnicalinformation.co...aboutnoise.htm
Hi,
I did, and found that the ground wire coming from the radio and going to the chassis the issue. the screw wasn't tightened properly.
Right now, everything is fine.
Thank you!
Thank you!
FrostByte27
06-01-2011 01:37 PM
