2012 coupe si race carz
stock 2012 si coupe
first mod at 2k miles,afe intake
install
bc coilover and rv6 2.5inch pipe came in
remove restricted down pipe
rv6 install
bc coilover install
drop statistics
Ultimate racing cat-back 3inch with secondary muffler
install
testing Acura TL wheels
between the brown,yes those two are dump rsx co workers
dump lexus co-worker
heading out
more to come.
install
rv6 install
bc coilover install
drop statistics
install
heading out
more to come.
Re: 2012 coupe si race carz
delete intake resonator which made a different with my afe intake
35 watt hid slim good ****,place all 4 ballast under headlight. 5k headlight 3k fog.
just install my rbc and it wasn't an easy task..
3in silicone cup was a bitch to install on 70mm tb..
few tips on PRL RBC
honda bond that coolant port because it will leak slowly
before
after
rbc bore to 70mm with 70mm zdx TB
custom bracket
install twm short shifter,cage bushing,and linkage bushing.
few tips on PRL RBC
before
after
custom bracket
tastfully modded i didnt do anything on my car was considering trade in but might hold onto her longer , have you tuned the car after the rbc and bolt-ons or did you just clean up fuel maps ? have you noticed diff that would make it worth the work ? also i never missed a gear or anything i know if i shift at the top of first real fast that i can almost hear a slight grind noise , its hard to explain makes a real quick noise but it dosnt hang up or anyting , have you noticed that with your car at all , there is only 5k mils on my car had it almost a year already .. only drive to work and back and to girls house.
car is already tuned with stock injectors.. no bull **** etune crap.
list of cars I've beat
s2000 ap1
2012 v6 mustang
350z
g35
rsx type s
8th gen si
as for grind noise I don't know and my next mod will be 8th gen si skunk2 cold air intake.
s2000 ap1
2012 v6 mustang
350z
g35
rsx type s
8th gen si
Located the grind noise it's the clutch master ... It's slow like the one on 8thgens , there is already a kit out to put the older em1 cmc on the 9th
?? car isn't that low.
no grind noise here for me.
will that shield cover work on a 2012 sedan ??? Your build got me glue to this thread...
I'm most likely get the rbc manifold, the hondata flashpro, and intake all together...
