Honda S2000 Honda S2000
how to reduce the oversteer and rear tires kicking out suddenly?
Old 01-02-2018, 05:21 PM
fuzzysig's Avatar
Default how to reduce the oversteer and rear tires kicking out suddenly?
i read some threads about a specific allignment that decreases the surprise buttsex from oversteer
just got my s2k (2002 ap1) with espelir springs
got stock wheels with extremecontact dws06 tires
but even with those it kicked out very hard when i was testing it out
turned into an uphill street and stepped on gas a little bit purposely to break traction to see the limits and it kicked out without any notice lol. didnt spin out but i did not like how it kicked out at all. was very hard to get it back in line.
it was a bit wet also
i dont know what kind of specs are on the current allignment either
besides cornering it drives fine. and it keeps somewhat decent traction on dry pavement.
but i can feel it wanting to move to the side alot when i drive
always feel one of the wheels chirp slightly on the corners
im planning to get 06-07 shocks and springs and wider tires on it later once i save up some cash
17x8 17x9 rear with some ultra high performance all season tires like dws06 or gmax or whatever i can find
questions
what allignment specs should i go with for best cornering traction( mostly to minimize oversteer)
what suspension is best for that? i read that they readjusted the suspension alot through the years because people kept crashing them due to rear tire kick out
anything else i can do to teh car to minimize the oversteer and rear kick?
PS: for captain obvious. its obvious that better driving skills help which is not what im asking. so you can move on now...
Old 01-04-2018, 07:24 AM
Tight-R's Avatar
Default Re: how to reduce the oversteer and rear tires kicking out suddenly?
If you use the search function on the forum, questions like this have been answered 100,000 times with 100,000 different setups from oversteer to understeer. Look it up.
Old 01-04-2018, 08:24 AM
Chance EG's Avatar
Alignment specs should be whatever the OEM recommends. Softer spring rate in the rear (AP2) would help a bit.
Personally I loved the tail happy nature of my AP1, but to each their own. I know for AutoX purposes a lot of people preferred the Ap2.
Old 01-04-2018, 04:18 PM
fuzzysig's Avatar
tight R if you use search button there are 100s of contradicting threads about every topic
these threads been up since 2001 and nobody bothers to update or clean up the threads. they are full of junk
maybe 10 years ago it was a valid responce to refer someone to threads because they were actually maintained and had images etc.
now its just bunch of crap with broken links and deleted images..
i dont know when last time you searched
ive been on this forum since about 2003-2004 trust me im not new and know how to search...
tail happy is great on dry pavement.
in washington it rains most of the year. not so great for happy tail when car goes sideways faster than you can let off the gas pedal. not even going fast maybe 25-30mph with dws06 tires
chance eg
there are specific alignment specs people found that reduce oversteer but most of them are aimed at auto-x or specific racing.
i saw one thread mentioning other than oem allignment specs that said worked well for street driving but i lost it and cant find it again i dont even remember what forum it was on
Old 01-05-2018, 09:59 AM
Tight-R's Avatar
Fair enough, instead of looking it up, stop driving like an ******* and the car will handle just fine.
Old 01-05-2018, 09:58 PM
fuzzysig's Avatar
why do you assume i drive like an *******?
if you cant answer please stop replying with nonsense
Old 01-07-2018, 02:08 PM
smilindave's Avatar
This is called snap oversteer. It occurs when the rear suspension reaches its limits in travel and then it lets loose. Try being smoother in transitions at turn in to apex and limit jerking the car to induce this. My 80 yo dad has an S2000, It is a very sensitive car to steering input when not in stock form. Dad's car has been on various shock/spring combos finally setteling on bielsteins with matching springs. For his this was best ride/handling combo for him. Yes, Dad will wear you out in a race.
Regards
Dave
Old 01-07-2018, 03:04 PM
fuzzysig's Avatar
did he have anything else done besides those?
what wheel tire size is he running?
i know what its called. im asking how to minimize it.
i have to run stock height because of my driveway.
Old 02-04-2018, 04:24 AM
rpg51's Avatar
I have an 02. My personal experience is that for street driving going back to the stock oem tire and suspension set up (if you have modified it) will work well. No perfect, but pretty darn good. I think there are definitely things that can be done to reduce oversteer and induce understeer. Best to search on s2ki.com.
Old 04-27-2018, 12:36 PM
snarlingbeast's Avatar
Universal methods for reducing oversteer on an FR car:
Stiffer front sway bar
Stiffer front springs
Stiffer front damping
Narrower front tires
Softer rear sway bar
Softer rear springs
Softer rear damping
Wider rear tires
Stickier rear tires
Old 10-09-2018, 02:17 PM
SharpeShooter's Avatar
Well, the simple answer is become a better driver. Snap steer is driver induced. Yes, you can spend a ton of money in stabilizer bars, springs and tires but the best thing you can do is be patient and learn to drive this car.
Old 02-05-2019, 11:38 PM
White_EG1's Avatar
Fuzzy you from teamsolcal?
Old 04-19-2019, 10:36 PM
sounds's Avatar
I agree with this advice.
I got my 2000 AP1 new, with 7 miles on the odometer. I ran it stock for years. I experienced some snap on extremely rough terrain, like railroad track crossings, but it always corrected.
What really impressed me is that the torsen differential will straighten up the car at launch, but admittedly that's mostly in a straight line.
After running stock for a while and noticing some bump-steer, I started asking for the Honda UK specs when paying for an alignment. You can find these online. This really improved the car to perfection. It's got a hair trigger on the steering with those settings, so you have to be subtle. But the car is tight.
Keep in mind that the Honda racing team designed this car, and I happen to think it's rather difficult to improve on stock. You might as well start stock, get used to the car that way, and then make your own mods if you feel unhappy with stock.
Old 04-20-2019, 03:58 PM
zeroptzero's Avatar
bit more rear toe in, wider rear tires, c/r front sway bar, bit more rear camber .
Roberts96accord
Suspension & Brakes
06-26-2017 06:34 PM
PatrickGSR94
03-11-2013 05:12 AM
jduguay5
Honda Civic (2006 - 2015)
11-22-2010 06:09 PM
MugenEg
01-03-2010 09:23 AM
gsr1289
09-14-2006 07:52 AM
Quick Reply: how to reduce the oversteer and rear tires kicking out suddenly?
