fuel damper line
fuel damper line
Hi everyone,
I wanted to see if anyone could point me towards any kind of walkthrough there may be to replace the fuel damper line on a 2000-2003 s2000. Unfortunately it looks like some mice put enough of a gash in it and cause fuel to spray out as soon as I turn the key to "ON" (causing fuel pump to prime). I believe the line I am talking about is number 3 in the attached picture.
Any help will be appreciated. I just hope I don't have to take off the whole intake manifold to replace it, but I think I may have to.
Thanks in advance!
Thanks in advance!
Re: fuel damper line
You don't have to remove the intake manifold. You have to get under the car to loosen the lower fasteners, and replace the two crush washers on the banjo bolt. Those washers are aluminum and OK to reuse 2-3 times with enough torque, but cheap enough to replace.
Type-Spaz
03-30-2011 02:12 PM
