Cluster pinout 2004 vs 2006
Hello friends!
I have an unusual problem. My car is 2004 year releas and it has 2006 or later cluster attched in it. Don`t ask why, i bought it the way it is.
So i`ve got 2004 cluster now in my garage and going to install it.
Problem is... i don`t have wiring pinout from 2006 year to install it properly. Ofcourse i can install it with wiring pinout scheme of 2004 year, but i`m not sure wich harness installed now (rewired 2004 or just oem 2006). It confuses me.
Maybe someone has a cluster pinout of 2006 year releas?
Thank you!
Thank you!
Re: Cluster pinout 2004 vs 2006
That 2006+ cluster won't work on a 2004.
The 06 and up went to a serial communication to display the coolant temp, check engine light, charge light, cruise control, and check fuel cap. I believe the this is also when they added the outside air temp.
You would still be able to see speed, rpm, fuel, brake, door and trunk open, blinkers, and high beams.
Yes, i lnow it ☺
It`s actually doesn`t work. That`s why i bought a 2004 cluster.
But to handle the wiring diffirances i need a cluster pinout diagram of 2006 year.
importboi22
05-31-2004 10:32 PM
