s2000 maximum amount to skim head
Re: s2000 maximum amount to skim head
That's a lot... have a Cometic head gasket made that is .018" thicker than stock to make it up. Problem solved.
Just make sure your P2V clearance is good. And like JR said, you can always get a thicker aftermarket gasket that can make up for the difference.
Also note that your compression ratio is going to be higher with that much milled off the head, unless you compensate with a thicker gasket.
driftingdonuts
06-02-2011 02:30 AM
