Honda S2000 Honda S2000
Help with header install
Old Feb 27, 2015 | 09:01 AM
speedfreek128's Avatar
Default Help with header install
Ive already searched and found nothing. What are good methods to install a header? I was able to remove the stock one after some wiggling and jacking the car up high. Then I removed the subframe stiffener bar and the passenger side engine mount/bracket. The new header gets caught up on the subframe.
Old Mar 1, 2015 | 11:27 AM
bigmacnfries's Avatar
Default Re: Help with header install
what header are you trying to fit?
Old Mar 1, 2015 | 08:13 PM
Invidia
Old Mar 4, 2015 | 04:50 PM
dagle's Avatar
the engine needs to come out for the header install.
naw jk, loosen a motor mount if you need more space (tilt the engine to the other side). You should be able to twist/tilt/wiggle it in there.
Old Mar 12, 2015 | 01:58 PM
Looks like that is the only way. Loosen the mounts, lift, tilt engine to get it in.
Old Mar 12, 2015 | 04:34 PM
dagle's Avatar
i didn't loosen the motor mount, i just had a friend tilt the engine using the crankpulley bolt and a breaker bar (away from the header).
Old Mar 17, 2015 | 11:56 AM
Might have to try that.
Old Mar 17, 2015 | 01:21 PM
bouford's Avatar
get the s high enough, you can get more angles to slip it through the bottom. gl!
Old Apr 9, 2015 | 09:00 AM
edmorl's Avatar
that's a pretty good idea, I'll have to keep that in mind
#Leo#
Dec 26, 2008 06:33 PM
RHardin15
Mar 28, 2007 05:49 PM
Sliced Beard
Apr 20, 2004 10:57 PM
roadawg
46
Nov 19, 2003 11:36 AM
GSR2001
Feb 22, 2002 09:09 PM
