RSX shakes at idle
RSX shakes at idle
Hello guys,
I just bought an 2005 Acura RSX Type S with 102,000 miles on it. Hopefully you guys agree the car is fine with that many miles on it. Paid just under $10k for it.
Anyway the car has two minor issues. After the car warms up the idle goes to the normal 800 rpm. The idle is constant. The car is not missing or having any other issues I can tell.
The other issue is they check engine light is on and has a code of P1172. Research shows that the primary oxygen sensor needs replaced.
Any suggestions or ideas for these issues?
Re: RSX shakes at idle
its pretty common for the primary o2 to go out on these cars over time. Just replace it and go from there. Has this car been modded? Factory ecu?? Hoping its a 05-06 primary o2 too.. You can have some oem primary o2's for cheaper on www.clubrsx.com
WHat is the other issue?
You already know the problem.... Why is this a thread lol
Fix the oxygen sensor that the car is even telling you is needing fixing. Then if that doesn't cure any of your problems come back and say, "well I tried changing the o2 sensor what else could it be?" lol
02 sensor
iacv(does k have this?)
my friend had the same problem on his gsr after replacing 02 sensor and idle air control valve it went away
We do have an IACV. If anything I would attempt to clean it before replacing it. Replacing it is VERY expensive since the dealership considers it to be part of the throttle body itself
I had my friend sit in it and he just thinks that was the way the car was made. He doesn't think the car shakes or vibrates abnormally. Does your cars vibrate? You can feel mine vibrate through the steering wheel.
The motor mounts are stock and look to be in good condition. We looked tonight.
As far as the check engine light we checked the codes tonight and it pulled 5 codes. All relating to the primary O2 sensor so its a sure thing now. That P1172 code pointed to a air/fuel issue and left me wondering if the O2 sensor really was the issue.
Am I just not used to the way this car idles? The RPMs are constant. It just seems rough to me.
Thanks for your input guys. Did I pay to much for it?
if the rpm is constant what exactly is the shaking feeling?
its not jerking from the car?
is it your suspension?
maybe your engine mounts are going out?
I exaggerated a bit I guess. Its just vibration. To me it felt like it was missing but I guess I am just not used to it. The RPM is constant so it probably doesn't have an issue.
Can you guys feel the motor vibrate while holding your steering wheel?
The idle in my '02 with >130k is pretty smooth. I don't feel any vibration in the steering wheel.
About two years ago I did have to clean the IACV. I wasn't driving the car often at the time (about once a month), so I don't know if that contributed to it. That was causing an erratic idle. Normally you get the high idle on cold starts until the engine warms up. When the IACV was sticking, after the high idle period, the idle would oscillate because the valve was sticking. IIRC it's magnetically coupled, so the ECU would signal for it to change positions, it would stick, and as a result, air coming it at idle wasn't what it expected.
This past summer I had an error code for the primary O2 sensor heater. I reset it once, and then it went away for a couple of weeks, and then it came back. After a couple of weeks I replaced it. It never affected my idle. It was easy to change.
i have the same problem in my 06 type s. it def vibrates real bad. And i drove another type s before i chose mine and the other one did not feel like mine at all. and i also have a few o2 code come up.
rubikscube
02-29-2012 04:54 PM
0h teh sl0w k20!!
07-09-2007 07:37 PM
