Adjusting alarm
Old Jul 31, 2009 | 08:39 AM
BigTwoThree's Avatar
Default Adjusting alarm
Hey, I was wondering if anyone could help me. I want to adjust my alarm so that its not so sensitive, but I know nothing about alarms and didn't install my alarm. The previous owner did. It is Python I believe. Or just my keyless entry thing is. Any help would be much appreciated
Old Aug 1, 2009 | 12:25 PM
fcm's Avatar
fcm
Old Fart
Default Re: Adjusting alarm
Without knowing the make and model of the alarm, [Python has more the 50 alarms] the only advice I can give is general, most DEI alarms use the "Stinger Double Guard impact sensor" about the size of a box of wooden matches, with one 4wire ribbon harness plugged into it and one adjustment "set screw" on the box, turning screw clockwise increases sensitivity and turning it counterclockwise decreases sensitivity, a few degrees of movement can make a big diff.
Some DEI alarms have the impact sensor built-in, and there is an adjustment **** on the main brain. 94
Old Aug 1, 2009 | 11:31 PM
Oh ok. This "magic box" wouldn't happen to be in a specific place or area of the car would it?
Old Aug 1, 2009 | 11:32 PM
Davus's Avatar
Usually around the steering column and such, pull the driver knee panel and look there. Also run along the ignition harness, you're likely to find at least one aftermarket wire there.
Old Aug 2, 2009 | 12:03 AM
Will try either tomorrow or monday when I have time. Thanks a bunch for the advice
ITR 692
Audio / Security / Video
Jun 15, 2012 09:09 AM
vinceiscoo
Aug 26, 2008 02:03 PM
goldaccordse
22
Mar 11, 2008 04:52 AM
Lost_clearance
Apr 21, 2006 09:50 AM
lynne818
Feb 22, 2006 07:55 AM
