cd player install??
Old Jun 29, 2009 | 01:45 AM
KILLAB17VTEC's Avatar
Genetically Gay
Default cd player install??
i just got a new cd player.puttin it in my 92 integra.i hook all the wires up.i'm not gettin no power to the cd deck??i check the number 10 fuse and is ok?help me out.
Old Jun 29, 2009 | 04:03 AM
mrdeadman's Avatar
They let me pick
Default Re: cd player install??
You hooked it up wrong.
Check your wires. If your deck has a "separate" fused power line make sure the fuse is in there.
Old Jun 29, 2009 | 05:37 AM
fcm's Avatar
fcm
Old Fart
It is fuse 14 - 15A, [hot at all times] and fuse 22 - 10A, [hot in acc. and run] both in under dash fuse box, and as mentioned the HU itself has a fuse.
Also as mentioned recheck the wiring, this may help... http://www.installdr.com/Harnesses/HA-Wiring.pdf 94
Old Jul 1, 2009 | 12:12 AM
Genetically Gay
alrite?i tested all the fuse under hood and inside.now the problem lies on harness that connect to cd player.I'm not gettin any power at the harness?is there like another fuse hidden there somewhere?
Old Jul 1, 2009 | 09:11 AM
fcm's Avatar
fcm
Old Fart
Both stock radio fuses are in the under dash fuse box.
How did you check the fuses, did you use meter/test light or just eyeball them? 94
Old Jul 2, 2009 | 01:35 PM
Genetically Gay
i use those test light?gettin all power except the adapter to cd player has no power what can be wrong?somthing unplug?help asap
Old Jul 2, 2009 | 04:39 PM
fcm's Avatar
fcm
Old Fart
Maybe adapter harness is miswired, the harness itself.
Check the white/blue lead, [hot at all times] and the yellow/red lead, [hot in acc. and run] at the stock radio harness plug, if there is power on both of them make sure the harness adapters yellow is lined up with the white/blue and the adapters red lead lines up with the stock radio harness plugs yellow/red. 94
Old Jul 3, 2009 | 09:22 PM
Genetically Gay
alrite?did some testing relook through the wires harness.findout what the problem is the green plug was not plug in tight.rewired the cd player poowww i got it to work now..thank for the help.
Old Jul 7, 2009 | 06:24 AM
Marcd_206's Avatar
free bump
hdj20
Audio / Security / Video
Nov 26, 2009 07:10 PM
1200 Hobos
Aug 29, 2008 01:09 PM
B16Acrx90
Aug 9, 2005 09:21 AM
ineedmoney
Jul 19, 2004 03:17 PM
ksyung
Jan 7, 2003 06:17 AM
