Help Electrical problems! Locks and deck
Old Jun 23, 2009 | 06:52 AM
tehteg's Avatar
Icon3 Help Electrical problems! Locks and deck
Hey guys, I need to get this fixed asap. So I'll just give you some background first on factors that could possibly be playing into this problem. When I bought my integra, the lady before me had an alarm system installed. After having the car for quite some time, I installed a deck, alarm worked for a couple weeks after, then stopped. Hasn't worked since.
So then last week a friend who's really into car audio stuff installed my sub for me. Everything was good sounded great, then next day a wire came loose from the amp. I reattached it, then everything was fine again.
Same day after it finished raining, went out to get my paycheck, leave my car it locks fine. Come back outside, car won't unlock at all, not even with the key on either door. So I had to use the key on the hatch and crawl in through there. Later that day, I still couldn't get anything unlocked, and found that if I hit the unlock button from the inside or the one from the remote and open the passenger door right after it unlocks then right after it unlocks it relocks again without me touching anything. Thats what I've been using to get in and out of the car for the last couple days. Also when I hit one of the unlock buttons the drivers side does the same thing, makes noise like it unlocks then locks again really quick but it actually doesnt unlock.
So now to add to this lock problem, randomly last night after I completely turned off my car, the deck stayed on for like 3 hours and I didnt notice it, so I got in my car and put the key in the ignition and kept like turning the key and then turning it off all the way, the deck still wouldn't turn off, and didnt until I completely unplugged it from the harness.
I've already been checking and double checking fuses, and wiring in the front of the car for anything loose or blown and found nothing.
I urgently need help if you know what it is or have an idea I need your help please!
Old Jun 23, 2009 | 09:03 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Help Electrical problems! Locks and deck
Make and model of the teg?
Old Jun 23, 2009 | 09:18 AM
tehteg's Avatar
1997 Ls, automatic....
Old Jun 23, 2009 | 05:10 PM
fcm's Avatar
fcm
Old Fart
I would start by unplugging alarm brain and see what happens.
If the door locks are stock they are "central locking", there is a switch in the drivers door actuator that signals door lock control module to lock/unlock the doors if the drivers door is locked/unlocked with key or manual lock lever, it may be the switch/actuator that is bad, [always on lock] or the switch lock lead is shorted to ground, possibly the alarm is connected improperly to the actuators lock lead instead of door lock module lock lead.
Start by unplugging the alarm brain and see what happens. 94
Old Jun 23, 2009 | 08:31 PM
tehteg's Avatar
My only problem is I can't find the alarm brain, and I have no idea how I'm going to get my drivers door open to work on it now too. But ya the drivers door won't work with key or remote, and switch on the inside too. Also now to get in and out of my car I have to go only from the passenger side, hit the unlock button if I'm on the outside and pull the handle really quick because when I hit the button it unlocks then locks again right after (same thing on inside of passenger door).
Any ideas how to get my drivers door open so I can work on it?
Also drivers side handle seems really loose from the outside.
Old Jun 24, 2009 | 04:44 AM
fcm's Avatar
fcm
Old Fart
Disconnect the batt., unlock the drivers door with the key or the mechanical lock switch/latch. 94
Old Jun 29, 2009 | 02:05 AM
KILLAB17VTEC's Avatar
Genetically Gay
i had this similair prob.what i would do is take out that cheap alarm and throw it in the trash.thats what messin with the car.even when that happens u can open the doors.about the deck i think u freind hook it up wrong so u should connect them wires again.
integcraze
Audio / Security / Video
Nov 3, 2009 01:23 PM
tehteg
Jul 3, 2009 09:42 PM
tehteg
Jun 24, 2009 12:11 PM
