Help with sub
Old Jul 22, 2009 | 05:54 PM
Maleek's Avatar
Default Help with sub
Hey guys, i have a 10" JL sub thats being powered by a legacy amp. Today i wired in a new ( to me ) cd player because my old one didnt have outputs. The cd player install went smooth like butter. But when i went to install the sub, i had a bit of difficulties
The amp is set to "mono" and is bridged. Before the amp power wire was even connected, the sub would play but it was very weak. So obviously i connected the power wire, and it still was very weak. I played with the amp, changed the bridge connections and still played very weak. the only time it plays decently well is when i hit the "boost" option on my deck, and with the amp turned up to the max setting, its still pretty weak imo. Somebody please help! Ps Im getting a proper ground, im getting 12 volts at it, and the amp power is ON. Please don't tell me i need a new amp
Old Jul 22, 2009 | 07:00 PM
mrdeadman's Avatar
They let me pick
Default Re: Help with sub
Did you have it wired to your old cd player with a loc?
Old Jul 22, 2009 | 07:59 PM
twentyhurtz's Avatar
i've seen amps come on minus the required power before by looping a ground through the rca's, etc. You have one of those issues that just doesn't ring a bell to me, its something you should probably have someone look at, its more than likely something minor if it is not the amp, but i don't even know where to start when asking question on this one, i could be so many different variables.
If it all worked "fine" before the Hu swap, you need to check head unit settings, and as stated above, are you using a module?
Old Jul 22, 2009 | 09:26 PM
Maleek's Avatar
I should clarify my original post. My original deck was NEVER hooked up to this system that i just installed, only the new headunit is. Im pretty new at the audio game, so sorry for my bad terminology.
Not exactly sure what a loc is, but im pretty sure i'm not using one. Espescially since i don't even know what it is, lol.
Old Jul 23, 2009 | 05:19 AM
LOC = Low Output Converter, it take high level speaker wire signal and converts it to a Low ouput (rca) but if you never had it hooked up then surely you don't have one.
92-LS-Civic
Audio / Security / Video
May 1, 2006 11:19 PM
young noob
15
Oct 1, 2005 07:27 AM
dcviperboy
Nov 17, 2003 12:16 PM
zcivicz
Mar 24, 2003 05:04 PM
jokerstud
Jan 13, 2003 10:34 AM
