Trouble with speakers
Old Jun 27, 2009 | 05:58 PM
hieuamn's Avatar
Default Trouble with speakers
Recently as I was driving on the hwy, bumpin to my cd then all of a sudden all sound stopped. Speakers just not outputing anymore sound for some reason.
99 stock integra headunit
Rockford fosgate 6.5 speakers all the way around
anyone got suggestions?
Old Jun 27, 2009 | 09:42 PM
kay@neighborhoodtrends's Avatar
Default Re: Trouble with speakers
99 stock integra headunit <------ Radio took a crap
are you running a amp to the "Rockford fosgate 6.5 speakers all the way around" ?
if not you radio quit on ya
Old Jun 28, 2009 | 06:12 AM
fcm's Avatar
fcm
Old Fart
Check the front speakers install, make sure the speaker terminals are not touching the doors sheet metal, [shorting out] a common problem when installing some aftermarket speakers into Honda/Acura doors. 94
Old Jun 28, 2009 | 10:16 PM
hieuamn's Avatar
No amp, radio seems to function just fine seems like speakers is the only quiters
and yeah friend also told me it might be touching metal so il check it out as soon as I get home from vacation. Thanks guys
Old Jul 5, 2009 | 11:20 PM
hieuamn's Avatar
Front speakers aren't touching any metal =/. any other suggestions?
Old Jul 5, 2009 | 11:37 PM
dohcvtak's Avatar
your speakers failed cause while trying to drive them hard with stock hu while under powering them?
Old Jul 5, 2009 | 11:56 PM
hieuamn's Avatar
yep seems that way from doing more research. i ran same setup in another car but didn't need amp... guess it couldn't handle it this time
Old Jul 6, 2009 | 05:59 AM
fcm's Avatar
fcm
Old Fart
LOL, it is unlikely that all 4 speakers failed at the same exact time and although under-powering speakers can damage the speakers it is not the under-powering that damages the speakers it is driving the under-powered amp into constant clipping that would burn the speakers VCs and that could not happen to all 4 speakers at the same exact time.
With that said there is a possibility that a VC got burnt to the point of shorting out instead of "opening" the result would be the same as a speaker terminal/tinsel lead/speaker lead shorting to ground.
That leads to my next suggestion, unplug and test the speaker VCs, you can use a multimeter set to ohms or even a batt., [a 9V works best], touch the terminals of the batt. to the speaker terminals, the speaker should "pop" and cone should move, [direction of cone movement will depend on polarity], the batt. will not indicate the condition of the speaker only that it does not have a shorted or open VC.
No sound "pop" and no cone movement = open VC, only that speaker would not work.
Very little sound and no or very little cone movement, [assumes batt is good] = shorted VC, that would trigger HUs protection circuit, turning off amp, no sound from any speaker. 94
Old Jul 8, 2009 | 11:07 AM
hieuamn's Avatar
both speakers popped and moved... this is so odd...
Outlaw-Hondaz
Apr 5, 2011 09:41 AM
Confessed
Audio / Security / Video
Mar 12, 2011 07:05 PM
Speed_69
Mar 10, 2006 07:22 AM
sykotic
Aug 14, 2004 09:23 PM
tianporn
Jul 12, 2004 06:36 AM
