Lighting HID/Xenon kits, Retrofits and Associated Topics
fuses keep burning help??
Old Feb 4, 2013 | 02:09 AM
lalo.00.gsr's Avatar
Default fuses keep burning help??
I kno theres a ground exposed wire somewere.. Wat are some good techniques in finding the problem
Old Feb 5, 2013 | 06:36 PM
nub's Avatar
nub
Default Re: fuses keep burning help??
Not sure what you mean by ground exposed wire. Blowing fuses would indicate a problem on the positive feed side.
Old Feb 6, 2013 | 05:36 PM
B20G2's Avatar
He means he has a dead short to ground.
OP care to elaborate some more on your problem? Pretty vague right now.
Type of chassis? Motor? Which fuse is blowing?
Once that is determined disconnect associated wiring. Reinstall fuse see if it holds, then start plugging items back in till fuse pops. It will give you somewhere to look.
This isn't the correct method, but can narrow down your search, not easy finding a short, good luck.
Old Feb 12, 2013 | 10:08 PM
Gsr dc2..cluster fuse and the lighting for the cluster goes out
Old Feb 15, 2013 | 03:01 PM
B20G2's Avatar
Is this fuse 25 7.5 Amp? Clock, Gauge and Indicator Lights? and Integrated control unit?
Anything change or install anything before the problem started to occur?
Old Feb 21, 2013 | 04:27 PM
HondaAccordKen's Avatar
A bad head unit install can do that. dash dimmer wire used for ground.
Old Feb 24, 2013 | 02:23 PM
kustomgixxer13's Avatar
try pulling the 15amp fuse for the radio and see what happens with the fuse that keeps blowing. if it doesn't blow, then someone hooked up the dimmer wires wrong.
CheddarPopcorn
Jun 30, 2009 10:53 AM
boostedb18kid
Jan 18, 2008 08:29 AM
GotGSR
Sep 2, 2004 08:59 AM
infinity257
Audio / Security / Video
11
Jul 20, 2004 08:01 AM
5thGenCivicKid
Mar 14, 2004 02:00 PM
