Lighting HID/Xenon kits, Retrofits and Associated Topics
99 headlights on Eg help
Old Mar 2, 2013 | 02:57 PM
hulsey's Avatar
Default 99 headlights on Eg help
I have a 99 front end on my Eg. Trying to redo the wiring cause the previous owner jacked it up. I have a engine bay harness for a 99, but not sure which wires on the plugs are for power to headlights so I can splice into the Eg wireharness. Does anyone know which color wires are what in the 99 harness for headlights? Thank you
Old Mar 2, 2013 | 03:18 PM
JuggerNaut-CTR's Avatar
Default Re: 99 headlights on Eg help
They are red and black just like a eg harness.
So the p.o. cut the head light bulb plugs off the harness?
Old Mar 2, 2013 | 04:34 PM
hulsey's Avatar
The p.o. Extended the wires like crap. Instead of simply using a 99 harness and wiring it in, he tried to splice the new wires in but cut wires in horrible places, twisted together and taped them. It's a cluster F of wires. I'm looking at wires and colors aren't all the same as the wiring diagram shows.
Old Mar 3, 2013 | 04:09 PM
DB8 RHD's Avatar
Both of you are on the wrong course...
The EG / EK Corner marker - Headlight plugs are Identical.... Trying to use a 96/00 Core harness, is just a waste of time and effort. Goto U Pull It, cut out some factory EG harness, splice, clean up the wiring, simplest fix.
Old Mar 3, 2013 | 04:45 PM
Curious how telling the op the are the same makes me be on the wrong course?
I honestly cant understand the op's funky *** logic thinking he needs to use that particular harness.
Old Mar 3, 2013 | 08:06 PM
DB8 RHD's Avatar
Because previous owner cut harness, and new owner is trying to use wrong harness.
I have no clue either, but its the honda world, some people try so hard todo things the wrong way...
Old Mar 4, 2013 | 06:02 AM
hulsey's Avatar
Guess ill make a trip to Pick a part and find the harness. The P.O. Cut out all the plugs and just spliced it together. I can't remember if there are stock plugs from the ecu to the harness for the headlights. Guess ill find out later today.
Nitrozity74
Sep 28, 2017 07:03 PM
mugenpowered
Apr 8, 2006 06:39 PM
electronb16si
17
Jul 26, 2004 07:02 PM
highmilehatch
Jul 24, 2003 02:09 PM
lodown414
Audio / Security / Video
Jun 20, 2002 04:04 PM
