Footwell lighting with domelight
Sup people.
First off let me just add that I'm not trying to rice out my car .
I understand alot of guys do LED strips in the footwell on a switch in their cars for that cool show look. I'm not going for that.
I'm curious if I can hook up two to my door switch/domelight wires. And if I do need a relay;how do I wire it up? 1998 civic ex coupe.
If it's not safe I can always opt for the switch type but I just kinda wanted a clean install,without looking riced out with a toggle switch imitating NOS or some other crap. SMH!!!
Re: Footwell lighting with domelight
Sup people.
Also, if you need instruction on how to use a standard automotive relay (which are available all over the net), then this sort of project is probably not for you.
As to whether or not you need one, that depends entirely on the capacity of the circuit you're trying to add on to, and the additional draw of whatever else you're adding. In other words, no one can answer for you without a lot more information.
All I'm generally asking is can I add two LED strips to my domelight/door circuit without blowing the fuse?
And if I could end up blowing the fuse; do I need to use a relay and wire the LED strip like a alarm domelight supervision?
Seriously, don't ask on here, go get the numbers for the new LEDs you wish to use, measure the existing power draw of the circuit, then compare the combined total to the fuse.
And don't replace the fuse with a larger one, as you'll risk burning wires before the larger fuse pops, rendering it useless. Do it properly with a relay and additional inline fuse.
Yes, if you exceed the fuse's capability, you'll need a relay, an additional inline fuse sized appropriately, and a direct line to the battery.
