Lighting HID/Xenon kits, Retrofits and Associated Topics
weird film or coating around headlights
Old 11-19-2014, 12:38 PM
cathcart96's Avatar
Default weird film or coating around headlights
see the line of what like some coating or something is breaking ? i dont know what it is but it makes the headlights look dirty or fogged , and where this stuff has peeled off the headlight looks brand new
the headlights are the original factory stanley ones ,its a 1999 ej6 civic coupe
Old 11-22-2014, 09:51 AM
LowTEC SaiMike's Avatar
Default Re: weird film or coating around headlights
From past experience , it is normal . Too much sun will cause it . It will get worse with more sun exposure. Always thought it was for UV protection
Old 11-23-2014, 02:57 AM
lazlong's Avatar
Tape off the hood and bumper so you don't ruin them. Wet sand the headlight with super-fine grit sandpaper. Dry the headlight off and apply at least several coats of clear spray paint. Remove tape and you're done.
Old 11-23-2014, 06:21 PM
cathcart96's Avatar
what number or grain level of sand paper should i use ?
Old 11-23-2014, 07:55 PM
lazlong's Avatar
The finer the better. Although, you can always get away with a little coarser grit if that's all you have on hand because the clear spray paint fills in the scratches.
This will last for several years- the more coats of clear the longer in generally lasts.
donger
Lighting
33
08-20-2010 09:37 AM
donger
08-19-2008 07:25 PM
97BB6Type-SH
08-31-2006 09:54 AM
Si Arn
08-11-2003 09:00 PM
Quick Reply: weird film or coating around headlights
