Lighting HID/Xenon kits, Retrofits and Associated Topics
Fog lights for 2000 Si
Old Sep 5, 2013 | 08:09 PM
69CanaryCamaro's Avatar
Default Fog lights for 2000 Si
I need some more lighting for my car!
Does anyone trust the kits on eBay for $50? Anyone had experience with them? Would I be better spending 3x the amount and going with genuine honda stuff?
Thanks!
Old Sep 6, 2013 | 04:33 PM
TunerN00b's Avatar
Default Re: Fog lights for 2000 Si
If you need useful forward lighting, you would be significantly better off with a set of supplemental headlamps instead of fog lamps.
Old Sep 7, 2013 | 03:35 PM
Factory headlights do an ok job getting light out ahead. I was just hoping for a good set of fog lights to help me see right in front.
I'm not interested in changing out headlights just need a little input on aftermarket vs Orem fog lights.
Old Sep 8, 2013 | 08:53 AM
grumblemarc's Avatar
The Grumpiest
Just get the eBay kit. You're going to anyway or you wouldn't have brought up price.
Old Sep 8, 2013 | 05:09 PM
well that helpful
Old Sep 9, 2013 | 12:06 PM
TunerN00b's Avatar
I didn't mention changing out anything. Supplimental means additional. Leave the factory headlamps alone. Add a set of supplemental headlamps where you would normally run fog lamps.
Doing so is completely legal in the US. You must have a set of standard headlamps, and can also run an additional set of headlamps or fog lamps (but not both). Don't buy anything labelled "driving lamps", as they can only legally be used with the high beams and only in situations where the high beams are legal.
OEM fogs don't do anything except make you more visible to other cars. None of them put any useful light on the road. Good aftermarket fog lamps are expensive. Cheap ones are only as useful as OEM.
Old Sep 9, 2013 | 07:12 PM
Nice. I will look into that. Thanks for your input!
carid
Nov 19, 2015 06:49 AM
darkintegra
Jan 27, 2011 10:27 AM
hamadiscool
39
Oct 2, 2006 04:58 PM
honda4674
Jul 10, 2006 01:59 AM
