Lighting HID/Xenon kits, Retrofits and Associated Topics
Turn signal failure
Old Jan 4, 2015 | 06:58 PM
champ421's Avatar
Default Turn signal failure
My wife bought some aftermarket dark headlamp assemblies for our 01 civic ex. The wire harness for the hi/low matches the car, but the turn signal harnesses don't match.
I have tried installing the new assembly, and since the hi/low have matching harnesses, they function. Because the turn signal harnesses don't match, I had to pull the bulb and harness from the original assembly and put it into the new housing. The turn signals and hazards still don't work. at all.
Can I splice in my own wire harness?
why don't the hazards work?
Old Jan 5, 2015 | 05:13 PM
lazlong's Avatar
Default Re: Turn signal failure
You can either-
a) Cut the connectors off and straight wire it.
b) Get some generic connectors.
With the a option you won't be able to pull out the harness when pulling the headlight assembly. While the b option requires connectors, pins, a crimper and the knowledge of how to do it correctly (tons of vids on youtube).
Old Jan 6, 2015 | 08:43 PM
LowTEC SaiMike's Avatar
It is always safer to not alter anything on the car side . if you can do the work on the aftermarket side, i would go with that option.
Pictures can help with these threads to help guide you through the work .
GetawayInMoscow
Audio / Security / Video
May 28, 2009 11:18 PM
plum
Mar 17, 2009 02:31 PM
Type-R32
Dec 30, 2008 04:56 PM
