Lighting HID/Xenon kits, Retrofits and Associated Topics
HID wire tuck problem
Old Nov 17, 2012 | 04:14 PM
_EF9's Avatar
Default HID wire tuck problem
I'm just about finished with a mild wire tuck, but ran into a problem. I extended the wires for the ballast and now the HID isn't working. Everything else works but the HIDs. Signals, corner lights, and signals work fine but the HID seems dead. Everything is plugged in correctly. Has anyone ever ran into this problem or try this and succeed with working HIDs? All the grounded is ground also.
Old Nov 17, 2012 | 04:35 PM
_EF9's Avatar
Default Re: HID wire tuck problem
would i need a relay wiring harness? just curious cause i only just the hid kit with the ballast.
would i need this to make the hid work again?
http://www.ebay.com/itm/Xenon-HID-Co...40885022213%26
Old Nov 19, 2012 | 12:12 PM
GLOBE AUTOWERKS's Avatar
hi, did you extend the HID cables by cutting into the wire of the HID ballast? We have HID extension cables up to 3 ft. that are fully plug and play.
Old Nov 19, 2012 | 06:59 PM
_EF9's Avatar
yes i did. the ballast and to the hid bulb itself. and what's the price?
Old Nov 21, 2012 | 07:12 PM
simple99'civic's Avatar
if you can post a picture of what you did maybe i can help you out. you don't need extension cables tho
Old Nov 23, 2012 | 05:16 PM
_EF9's Avatar
Well my relay just came in and still doesn't work. All I did was just the black and red wire from the HIDs and extended with 18g wires down to my seat where I planned on hiding the ballast. Look at the pictures.
If anyone else knows the problem, let me know! This is pissing me off. Don't want to buy new HIDs. There has to be someone who ran into this problem and solved it.
Old Nov 24, 2012 | 10:34 PM
_EF9's Avatar
244 views and no help. post it somewhere else? hmmmmmmmmm
Old Nov 25, 2012 | 05:58 PM
_EF9's Avatar
PROBLEM SOLVED! Oh why thank you HT, you guys are the greatest!
cilvia
Lighting
Jan 20, 2008 06:32 PM
speedstar-racing
Jul 30, 2005 11:53 AM
b16hybridsol
Sep 25, 2004 01:45 AM
mrmigos
Jan 29, 2003 03:55 PM
