1996 acura integra cluster lightings not working
Hi honda tech. I've been looking for an solution all over and I hope you guys can help me out!!
PLEASE REAd everything
So my 96 integra cluster lights are not working. The lights for the temp, tach, speedometer, and gas gauge does not work. EVERYTHING else works like the blinkers, check engine light, highbeam, etc. I've never had problems like this before until I installed a sub and amp. The problem did not start until few weeks later, because everything was fine even when I had my amp and sub in. When I turn up the volume or bass, my fuse would go out. Or if I would launch my car or if it would jerk, the fuses would blow out too. I would then simply replace the fuse with the same size. When the fuses goes out, my entire dash light and running lights would go out. But this keeps happening over and over to the point where it would blow out where I don't even have to do anything, it would just blow up by itself.
BUT t was able to stop it blowing out after my 8th or 9th time replacing the fuse. Everything was working properly but then, the instrumental lights gogoes again, AGAIN. But this time, the fuses are still good. So I've been stuck with this problem for a very long time now, I've been using a ghetto flashlight to see how fast I'm going. The cluster and bulbs are still good. I've tried a different cluster aND ended up having the same problem where everything but the lights work. I've tried checking my dimmer, the wires to my amps and subs, the relay, the fuses, , but everything is working fine. Im going to check the ground to see if there's a short, aND replace the door jamb. I pretty much tried almost everything so far, but I was hoping to ask if you guys know anything.
IF YOU GUYS HAVE ANY QUESTions OR ANSWER S. PLEASE PUT THE DOWN ON THE COMMENTS
Here's a video of my car of today
Integra cluster lights not working: http://youtu.be/8iWjhxm0DQo
rodimus
08-03-2005 06:57 PM
serboy00
12-20-2003 06:49 PM
