View Full Version : Paint and Body
- Removing scratches from plastic AVCR screen...
- Painting on Carbon Fiber products
- having body shop rocker/quater section
- Question about Acrylic Urethane Reducers
- Used Aircraft remover to remove paint from rims......... Yes i used the search botton.
- How do you repair a C-West Body Kit? : Pliable Fiber Reinforced Plastic
- crx gettin ready to be painted53P
- Body Filler Question
- Who paints cars in PA/NJ area???
- Paint Gun Question
- Removing sticker Pin Stripe
- licking problem!!!
- good way to clean CF Hood
- Gold Color Code for Wheels
- What paint to use to paint wheel wells and undercarriage?
- anyone in socal that wants to paint my car?
- info on how to primer
- Anyone know of a solid deep black paintcode?
- 91 crx hood emblem
- this cant be good...
- How to make a copy of a urethane lip???
- preparing to paint hub caps
- question on air gun
- What kind of paint do you use?
- white integra with black slips? or whiite slips?
- Single Stage
- Painting my SE rims (sunflowers)
- projekt camo sol
- home garage paintjob
- stripping interior, spraying with enamel rustoleum rattle can.. advice please
- How do i give stock parts an anodized look?
- Cleaning an Engine Bay with corrosion/oxidation
- paint dust remove?
- Painting EG Side Moldings
- Did some wheel polishing.......*pics*
- SHAVED MOLDING's ......PUKE......
- how much paint to spray eg hatch?
- passenger door falls
- Best air hoses
- bondo inside an engine bay?
- POR-15
- Post your Filter/Regulator systems
- Polyurethane Topcoat is this paint good?
- wax questions
- Tips for tree sap
- Dented frame
- is it worth it?
- Fix scratches with this?
- Is this any GOOD for its Price?
- Headlights are worsed after cleaning kit
- dent removal
- Flat black engine bay
- rusted 1/4 panels
- jdm front on da?
- carbon fiber yellowing restore.....
- Applying Polish, over wax?
- Going to be doing a color change... questions involving work..
- post your self etching primer.(army green) car.
- semi gloss auto paint job.
- Paint code for 2001 Prelude
- help on how to prep a car for paint
- imput on Quarters on this 300 doller beater i bought
- Question about window visors
- removing rust and body repairs how hard is it???
- shaved door moldings... solutions ideas?
- Quick question
- I tried wetsanding carbon fiber hood, came out dull and scratchy, need polish?
- bc/cc question
- sandblasting
- Question about stainless steel
- Quarter Panel Question
- hot rod black primer? will it fade?
- 92 civic cx....1/4 panel question....
- EBAY PAINT... is this good?
- Sorta noobish wheel painting question...
- looking for a flexible coating for polyurethane body kits
- Single stage paint questions
- Aftermarket and OEM front bumper fitment.
- freshly painted
- Is It just me?
- Fatty dent in wrong place
- looking for a flat board sander
- painting sir spoiler
- nighthawk black pearl
- Ideal tempeture for paint?
- Rencent paint job...weakens metal? or weak paint?
- dupont paint shop paints?
- paint runs
- drooping ceiling fabrik
- anyone heard of DuPont?
- What color should i paint my 00 Si?
- whats the best way to lay clear?
- Anyone know what color this is?
- preping new body panels?
- What is the BEST Paint Gun?!
- Painting your own car... Equipment?
- SHOPLINE PAINTS Q'S
- wet sanding and buffing questions please help?
- 93 integra hatch installation?
- best clear coat for my rims?
- 92 cx build
- 30 dollar paint job
- best way to remove waves in door panel?
- orange peel question, pro painters please help
- Question for anyone who has had their door jammed shut
- Touch up paint in a spray can
- buffing
- painting designs on fenders
- Painting car with Spray Can
- 95 honda core support
- wanting shaved trunk
- The Test... Porter Cable 7424 and 3M Rubbing Compound/PERFECT-IT III
- $50 engine bay paint job
- clay bar question
- wetsanding carbon fiber?
- paint
- Please what color is this?
- Any Recommendations For a Primer Paint Gun???
- Build Thread: 50$ Paint Job, EF style
- help! i chipped my fender off!!
- Removing scratches from bumper
- how do u get overspray off of glass?
- powdercoated valve cover = blown engine?
- how do you remove scrapes on your lip from bottoming out?
- Polished BBS ra Lip!
- What should I do
- help drivers side rear fender corner panel hit
- Clear Coat
- Black Chrome Paint in a Spray Can?
- Fine wire wheel, for paint removal???
- Bumper support
- Any of you replace your rear qtr panels on eg?
- ppg tech data
- door dent
- Some detail pics....
- powercoating my rims
- Whats a good pait remover ..
- plates to block off top and bottom of engine block??
- need my shine back
- after wetsand problem
- HELP!!!!HOW TO MATCH OLD PAINT WITH NEW!!!
- How to get paint off my paint
- Del Sol paint job
- 98+ front end proble
- Earl Sheib Vs. one day paint
- where can you get VHT wrinkle paint???????????????
- Before my eg goes in to paint
- Painting my eg.
- Pearl White with Champ White
- Horrible rust problem. Project car
- did diy rusto paint job a few months ago. how can i make the paint harder?
- Anybody know a good painter prep guy?
- gunmetal paint code
- Rattle can primer okay?
- Need some help,
- looking for a good dent remover
- Attaching bumper to rusted quarterpanel
- 91 CRX looking to have both quarters replaced
- 94-97 real lip install
- Interior Paint Color Change
- Any way to improve look of flaked clear coat?
- removing over sray
- Best paint stripper?
- Epoxy primer needed??
- gotta question: car schools painting for cheap?
- wetsand after fresh paint?
- i need paint codes..
- pic request of 4thgen prelude with spoon sports yellow
- wetsanding question
- powder coating
- Fiberglass/Carbon fiber fenders.. good or bad?
- Peanutbutter on carbon fiber???does it work
- Painting problems.
- Debadging Accord and LX logo
- best way to fix a sckratch on a carbon fiber splitter??
- PowderCoating Stainless Steel
- Carbon fiber lip repairable?
- where to buy paint?
- Gotta kill some orange peel...
- civic flat bottom under tray???
- what do i use to buff curved areas/bumpers?
- is my air compressor strong enough for this?
- Paint Code
- Best paint gun for the money?
- Anyone work at Maaco??
- Paint Color
- Need Help on 50$ paint job???
- need help with retsoring carbon fiber hood.
- Paint / Install question.
- whats the best way to preserve my fresh paint job?
- Adhesion/bleeding
- I need a new paint job and some help...
- 94 coupe
- CRX door skins install. how much would this cost?
- need help!?
- Cleaning a dirty engine bay
- Hood dents from fallin accorns
- single stage
- Trimming fender edges?
- Replacing Panel
- Faded Console how can I paint it.
- :: CUSTOM VALVE COVER ::
- removing pin stripe ?
- lining up radiator support
- COLOR CODES FOR HONDAS 1996-2000
- Dent/scrape on accord
- professional painting process
- 98 integra front end
- So i wake up this morning only to see
- over spray help
- hatchback paintjob
- how bad is this
- removing battery acid from paint?
- Need help on fixing this dent.
- More than 1 gray . . . ?
- Fresh Single Stage Paint Job
- Prepping for paint questions BB6
- prep for paint whole car BB6
- Any Paint Booth's for hourly rent in Orange County,CA?
- painting gurus
- waves
- Clear coat scratches..how can I get rid of them?
- Need a good body shop in the San Jose, CA area. Any references??
- for people that paint for a living, fluid tip and shop line paint
- help asap!
- ebay paint?
- painting my em1
- I think this is the right place for this question
- Lexus Graphite Grey Pearl Color Code?
- Gloss Black 50$ paint job
- Black 91 NSX.. How to freshen up the clear coat?
- Need some help repairing this... **pics inside**
- devilbiss finishline not spraying clear correctly. help!
- rust keeps coming back!!!
- how to take double stick tape off bumper safely...
- OFFICIAL EG PAINT THREAD
- Tips on spraying single stage paint.....
- Barcelona Green paint code...searched not in paint code list
- rear quarter panels
- sanding...
- How muc will it cost??? help??
- Painting the Interior....
- Detail, Black car question!
- can you make a kandy coat with miking a drop of color in your clear
- Is this paint/body job feasible for $1000?
- painting polyurethane body kits
- Question about PDR (Paintless Dent Removal)
- Pic Request ---Desert Mist Metallic YR-538M---
- use base coat as a primer for 2nd time job (same color/code) *respray*
