rust keeps coming back!!!
Old Oct 10, 2007 | 12:58 PM
1badassEG's Avatar
Default rust keeps coming back!!!
I'm getting ready to paint my EG and there is one spot that will not stay smooth where it was filled. I have sand blasted this spot down to bare metal, because it was a slight rust hole, then filled it and sanded smooth and shot some rust preventative primer over it for the time being and the **** is still bubbling through slightly. It's above the back right quarter/fender right above the tire. What should I do to get this to stop for good? Any help is appreciated.
Old Oct 10, 2007 | 05:43 PM
slow_srt's Avatar
Default Re: rust keeps coming back!!! (tripp4ever2003)
I'd cut out the rust and make and weld in a patch. Or if it is small just weld the hole up. If you just want to fill it without doing this use duraglass instead of regular filler as it will not absorb water from getting wet on the backside as regular body filler will.
Old Oct 10, 2007 | 07:36 PM
01LXCoupe's Avatar
You could use some POR15 on it.
Old Oct 11, 2007 | 05:13 PM
1badassEG's Avatar
Default Re: (01LXCoupe)
what exactly is that, some kind of spray??
Old Oct 13, 2007 | 02:30 PM
welfarepc's Avatar
POR15..its a paint that chemically stops rust from reforming.
it almost sounds to me like your bubbles are gas/moisture trying to escape not rust reforming...
if it is rust, welding in a patch would work very well...
there are also plastic patches you can buy that you glue over the existing panel, then remove the seams by using filler and repaint
Old Oct 14, 2007 | 01:19 PM
doubleshotz's Avatar
Default Re: (welfarepc)
Rust keeps coming back like child support checks.
From my experience POR 15 didn't do ****. Just cut and patch, prime seal and spray. Pull out quater linings (rubber). Good luck
Old Oct 17, 2007 | 11:58 AM
Diyracing2's Avatar
Default Re: (doubleshotz)
If por15 didnt do ****, you didnt use it right.
You said it was a rust hole. If bondo has any access to moisture, its going to bubble and come off.
Rust needs moisutre. So once you figure that out, your problems will stop.
Old Oct 17, 2007 | 08:04 PM
chitownrida's Avatar
por 15 didnt do much for me either, but then again i think the rust needs to be compeltely encapusulated in the por 15
H22EG'z
Paint and Body
Jun 17, 2010 11:09 AM
SixxT9
Jun 21, 2009 12:04 PM
MelszEg6
Dec 27, 2008 09:11 AM
stevescivic
Sep 24, 2006 09:39 PM
4runner
Jun 7, 2005 03:21 PM
