wetsanding question
Old Oct 16, 2007 | 07:55 PM
Timmyflys's Avatar
Default wetsanding question
sorry newb pAINTER HERE I thought i would just go ahead and try my first paint job do you wetsand after you lay down the clear coat??? you don't wetsand the basecoat or anything im tryn to find this out asap thanks
Old Oct 16, 2007 | 07:56 PM
Genuine Rolla's Avatar
You don't wet sand the base unless you have inperfections in it. you wetsand the clear, remove orange peel and things like that...then you buff it.
Old Oct 16, 2007 | 08:00 PM
Timmyflys's Avatar
Default Re: (Genuine Rolla)
like a run i would have to wetsand that b4 clear coat right do i have to lay down anther base coat if i wetsand the basecoat thanks
Old Oct 17, 2007 | 10:42 AM
WihaSi's Avatar
Default Re: (Timmyflys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmyflys &raquo;</TD></TR><TR><TD CLASS="quote">like a run i would have to wetsand that b4 clear coat right do i have to lay down anther base coat if i wetsand the basecoat thanks</TD></TR></TABLE>
If you ran your base coat, that means you are putting way too much on, not moving the gun fast enough, way too close to the panel, air pressure is too high, or a combonation of all the above. Base coat is supposed to be applied as a "medium" coat, you don't want it dry, you don't want it wet, and you don't want to achieve coverage in 1 coat.
And yes, you will have to sand that down, and re-base before clearing.
daddycivic
Paint and Body
18
Jul 24, 2007 10:37 AM
lude-tec
Jul 29, 2006 07:48 PM
dxhatch93
Sep 24, 2005 11:51 PM
XxBeSxX
Apr 10, 2005 12:15 AM
tranquil
Oct 30, 2004 03:53 PM
