Adhesion/bleeding
Old Oct 14, 2007 | 08:11 PM
thirdrail's Avatar
New User
Default Adhesion/bleeding
Am I going to have any adhesion/bleeding problems in spots like the following?
Old Oct 15, 2007 | 02:47 AM
Disease's Avatar
Default Re: Adhesion/bleeding (thirdrail)
Who knows LOL. Prep it right and you won't have adhesion problems. Paint properly and you won't have blending problems.
Old Oct 15, 2007 | 03:58 AM
Pockets's Avatar
you wont have adhesion problems because of the scratches (mechanical adhesion) you DO have to prime a repair like this, if you try to seal and paint it it will die back for sure.
Old Oct 15, 2007 | 04:37 AM
WihaSi's Avatar
You're going to need to use a filler primer, and block it down. After that you will need to use a sealer primer. Just make sure to gain coverage with your base coat.
Old Oct 15, 2007 | 12:30 PM
vtecrich's Avatar
Default Re: Adhesion/bleeding (WihaSi)
Prime it with filler primer, block it down, and then your ready for sealer and base. If you do that you shoudnt have any problems. Good luck.
00trdtaco
Paint and Body
Dec 15, 2008 01:47 PM
SLO Sol
Paint and Body
Nov 1, 2007 07:13 PM
learning process
Paint and Body
17
Oct 9, 2007 10:02 AM
swappedcx
Paint and Body
Aug 13, 2007 05:52 PM
