lining up radiator support
Old Oct 13, 2007 | 11:58 AM
learning process's Avatar
Default lining up radiator support
i need some tips on welding in a radiator support on a 98
civic hb... should i just attmept to weld the spots from the previous rad support?
i'm trying to have good fitment when all is done... car was backed up on but just pushed in headlight and bent the rad support pretty good.. so i bought a brand new honda one
Old Oct 13, 2007 | 07:01 PM
Disease's Avatar
Default Re: lining up radiator support (learning process)
When you take it off you will see paint marks. Those are kindof like guide marks. Easiest way to do it. If you can get a frame chart for your car then get it and use it to take under hood cross measurements to make sure it is square when it is in and it will be in place. Put a tack on each side and put the hood latch in and make sure the hood closes. If it does, weld it all in. Grind your welds down. Clean all your welds front and back, wire brush. Put an acid etch primer on the welds, front and back. Put seam sealer where it needs it and paint. Good luck buddy.
Old Oct 13, 2007 | 10:55 PM
Default Re: lining up radiator support (Disease)
i tack welded it in but i think it's still off.. i'll check it tomorrow... i'm kinda drunk... sucks...
Old Oct 14, 2007 | 01:56 PM
any other tips?
Silentz
Jun 8, 2018 05:56 AM
GraphiteMW
Feb 17, 2009 09:59 PM
88 rex
Sep 8, 2005 04:37 PM
HybridHatchback
29
Jul 30, 2003 11:17 AM
