View Full Version : Paint and Body
- Metal in clear...wtf HELP!
- Prelude body repairs and paint
- Video of my friends Freshly painted EJ1 clean!!
- Repainting the same color questions.
- Rust Repair (Pics)
- ej6 front bumper questions.
- Painting Engine Bay with NO AIR!
- bumpers keep peeling paint...
- 92-95 honda civic coupe bumper on 94 honda civic sedan
- Need HELP/ADVICE: '93 Del Sol S Driver Side Door Handle Replacement
- EK Type R side skirt
- is this acceptable?
- '98 civic ex coupe collision repair
- guess the color
- New Painting Technique
- Any good paint shops in San Diego CA
- OMNI MBX compatibility ?
- PAINT JOB
- Spray gun recomendations
- Anyone try 3m ppf on headlights?
- How do I know the CFM rating of my air compressor?
- Help removing scratch/scrape paint from car??
- Show me your EGs. Paint color ideas!
- EG coupe shaved body molidngs :/
- Custom Hydrographics
- What color should i paint my center caps
- Different colored door handles?
- Is a wrap just as clean and durable as paint?
- color change
- License plate mounting?
- Tint/Honda Civic 4dr 97
- Bent hood on ends, easy fix?
- Dc2 type r steering wheel fade fix? HELP
- car fixed
- How to do a cheap budget paint job?
- Paint code or Name of paint !!
- Rust at bottom of door w/ pics - fix or replace
- Please help out, color identification.
- HELP Save my Cowl
- 7th gen Accord door moldings
- HELP!!! Painting my 91 CRX
- Carbon Fiber Hoods
- it looks nice but is it pointless?
- First Time Doing Bodywork & Painting
- Best Way to Remove Paint from Engine Block/Head
- Help with painting body pieces.
- single stage pearl buffing?
- Vinyl Paint removal
- power sander or air compressor sander ?
- Front End Repair
- which white paint is better????
- rattle can to decent paint job
- anyone ever do a rattle can paint job? any ways of making it turn out good??
- Torque Mount Frame Replacement?
- VHT wrinkle red valve cover sanding letters do i need clear cloat???
- 95 accord front bumper sag repair?
- Custom Fiberglass/Fleece or Carbon Fiber Piece.....
- Recommended sites for Acura parts purchase?
- what sand paper to use and tools
- Hood gap/Sagging bumper EJ
- Em1 drivers tower damage :(
- Question about gutting.
- What is your favorite OEM Honda Color?
- Any other OEM Honda teal paint codes other than Midori Green?
- 01 S2K rear quarterpanel damage
- Does one have more pearl blue than the other?
- Need help identifying paint of vinyl wrap....
- Factory Paint vs High Quality Body Shop Paint?
- How much and where to get EM1 floor repaired?
- Euro-R on ek hatch is it possible?
- Correct Paint color
- Duplicolor Perfect Match Rattle can Pics
- Thinking of brushing clear coat onto freshly painted wheels
- help with paint removal on wheels
- ITR Front End Conversion
- Need A Paint Job
- How much to paint a crx?
- Habanero Red or Milano Red for 93 Civic Hatch?
- Bubbles on MDX's grill? (see picture)
- How to remove 1995 civic front bulkhead parts.
- what is wet sanding/ sanding for?
- cheap paint setup
- wat color is this (RED)
- Show me your guns.
- milano red or milano red pearl?
- OEM Mirror
- Carbon kevlar hood repair?
- Dupli-color vs Rustoleum
- Rear wheel well Quarter Panel 96 coupe
- Where to source screws/bolts?
- Seam sealer repair - recommendations
- Painted on pin striping- tips for removal?
- 2000 Ek with 98 JDM Honda ITR front end?
- Tackling Rust
- I want to primer my car
- Hondapartworld.com legit OEM? or No?
- Can epoxy primer be sprayed over self-etching primer (without ill effects)?
- 05 RSX $5000 Trade-in As-Is ---or--- Repair body damage & sell?
- 94 civic body panel LOOK !
- Paint Sunburn
- My em1 and the accident :((( plz help!
- is a pre mixed factory color a cheaper paint job than a custom one?
- any suggestions?
- how to fix welds on fenders from conversion
- Leak Hunting, Is This Bad?
- PIC request
- First time painting anything large. Does this sound right?
- Quantum Silver Aston Martin DB9 - New Paint - My Integras story.
- Best place for Paint Job in SoCal/OC?
- Metal on Metal adhesion
- How should i mount a fiberglass lip?
- What type of paint is this
- CRX Metal Fenders?
- repainting my 00 ebp si
- Color sanding metallic single stage?
- Info Request: Bending Rust/Rusty Metal
- Has anybody done c/f wrap on a hood?
- Painting EBP in sessions?
- Sand / media blasting
- primering a accord
- lap or flange joint on quarter panel
- body filler
- Oem eg hatch mud guard fitment
- What's the best way to paint your car ?
- Wax? Polish? Compound? I'm lost.
- 2012 civic front bumper
- how should i go about this rust :(
- 99 Civic window Moldings, do I need to pull glass to replace them.
- Vinyl Wraps - Pros, Cons and everything in-between.
- door panel question
- Emblem glue Eraser Wheel????
- paint problem
- Paint Transfer Removal
- and because 1 was not enough
- 92 Honda Accord Rustoleum Paint Job cb9
- Anyone have pics of a Duplicolor paint job?
- Removing Underbody Dirt and Rust Proofing
- Need new skintone
- Removing Dealer Info/Advert FROM tailgate.....
- How do you care for a flat (black) paint job?
- Project Thread: Rescuing an EG hatch, partial resto, full refinish
- Two-tone anyone?
- Rust, what work, what doesn't?
- EG noob door question
- Custom Upholstery
- NEEDED STOCK FRONT BUMPER FOR 2000 HONDA CIVICSI
- Carbon Creations parts wavy
- Body tech salary.
- Got hit and run, how much to fix this?
- Autobody supplies, yes, I searched
- Need help with paint prep work
- rear toe bracket
- Brand new OEM door skins and full quarters 93-95 Coupes
- Hood doesn't Close completely
- Rust under driver seat
- Front Bumper Replacement - What part is this?
- How to get off double sided tape off my bumper?
- How much does a good paint job cost?
- Fender Sidemarker Cutting
- How do you put on side skirts?
- bondo or fiberglass?
- Surface rust on my hood
- How do I go about spray painting my lowering springs.
- How much paint do i need to order
- Paint Protection?????????????
- 1993 Series Civic Body Repair Manual
- Dippedparts.com bad experience!!!
- Wheel Trim Painting!
- What to do??
- Body trim?
- Can i save my Carbon Fiber??
- 95 integra rear quarters
- preventing rust on calipers without paint
- what colour wheels too put with my car respray..
- What type of Paint? Please HELP!
- 92 gsr spoiler chip.
- Need Help body work 94 accord
- What color is this? Researched everywhere!
- Advice neede, rear-end repair.
- can anyone tell what this is?
- Painting Suspension Components, Is it worth it?
- body kit looks... looking for opinions?
- harbor freight HVLP guns, whats the minimum tank requirement?
- Cloudiness in Carbon Fiber Hood
- Paint questions (Non-Honda)
- Anyone know where to get these fasteners?
- how to i fix a terrible paint job?
- Integra DA front conversion
- Painted Turbo compressor housing??
- Exterior paint/dent/rust help! Help massively appreciated!
- What have i done...
- How much primer to paint a 93 hatch
- Primer question
- Lifted spoon spoiler?
- Fiberglass Baseplate Repair
- seam sealer
- ONE QUICK QUESTION! HELP me PLZ!
- Anyone knows where i can get a RHD conversion done near NYC?
- Plasti Dip a whole car?!
- C/F hood - re-clearcoat possible?
- Body shop near Syracuse, NY?
- Sanding before Polishing on Wood with Mirlon?
- how do you the panel under the tail light on a 96-2000 civic coupe?
- detailing supplies
- valve cover help
- BodyFill Over Polyurethane? Will it crack as it flexes?
- Body filler, Primer 2k or etch
- Can you use a vinyl cutting machine to make a graphics overlay for painting?
- What are the fasteners called that have a rounded head
- body paint shops , soCAL
- Can I use rattle can primer before i paint with a paint gun?
- So I wetsanded, cut and buffed. What do I polish and protect with?
- Just got backed into/insurance help
- Need help fixing this?
- is this fender repairable? s2000...
- Paint color Id
- Bolt stuck in frame
- hypothetical question
- Project EG want to sharpie then clearcoat
- After I Wetsand.... (bought lots of crap I dont know how to use) *PICS*
- Any good reputable body shops around Columbus/Dublin Ohio area?
- SRDFTITAN'S 97 EJ8......Oh god I decided to paint my own car!!!
- eg paint question
- Reclearing Carbon Fiber Mirriors? Help :)
- Which color 2 choose SSBP or Voltage DB8
- Found Car Rust on the SidePanel!
- RANDOM ORBITAL WAXER/POLISHER
- Thoughts on plasti dip?
- anybody use black lacquerd paint?
- POR15 Durability on suspension components
- cant figure out this color??
- 99 Civic EX project
- Eg hatch bolt/screw list
- 95 Civic DX damn rear bumper!!
- Repairing Sun/Paint Damage
- 95 Civic DX frontal crash
- Vynal paint dashboard
- Has anyone used Advantage Refinish clear?
- is single stage paint wet sandable/color sandable?
- 1999 si color
- trying to find out where im rubbing rolled fenders
- suspension frame/undercarrage painting.
- Anyone have a source for inexpensive carbon fiber sheeting?
- Cheap body work and paint upstate?????
- What is needed to paint polyurethane lips??
- Guide coat before final sanding?
- Rage only, or Duraglass + rage topcoat for small rust hole
- Door Dents and Creases. Sand down to bare metal for filler?
- 95 integra tunnel hatch
- Paint on Window Molding/trim...
