- little rough edges
- Ah I forgot, one more question, primer sanding
- When painting... do you ....
- How much gap do I need in this project?
- sanding bottom frame wheel well paint etc lotta questions help please
- 7075/6061 aluminum powder coating...what do I need to prep it with?
- New to autobody detailing
- Best Hood Pins....
- Red Matte?
- flat purple or other
- couple q's about painting
- need someone to paint my front end.
- Interior Paint
- Flat paint job protection
- baking headlights
- Satin/Matte Black?
- what supplies i need for flatblack paint? help
- Rust on Quarter Panel?
- Best clearcoat to use?
- Painting my car for the first time
- Sandpaper plus block equals bodywork. Exterior build thread.
- Original Paint Question
- Best Gold Color/Shade!
- Interior Redo
- Best fitting body kit for 89 civic hatch
- ek quarter panel honda sectioning guidelines?
- window washers or no...
- How much work to fix this front end damage?
- Any benefits from sanding existing primer?
- What colour is this?!?!
- Getting it Ready
- Whats a fair price to paint a fender. details inside
- How much am i looking at?
- Em1 Part numbers
- rust spot
- ? about paint my crx myself
- Painting over high quality paint?
- crinkle red paint for valve covers?
- I need my car fixed...and painted...can you help!
- What grit Sandpaper?
- Mix Bondo
- What do you guys and gals recommend
- Darkest Black Paint
- advice on how to remove interior paint?
- I need a someone to spray in NORCAL/SOCAL
- How exactly is Matte/Flat Black made?
- cf hood
- Best shade of white
- Engine Painting WIthout Removing The engine
- what is the best way to fix this>?
- CTR Stickers.
- Sanding question..
- problems with painting carbon fiber? examples?
- Satin Black Paint Color Code
- ek front bumper support
- paint help
- UnSatisfied with KC autopaint
- air compressor hp question
- 1990 wide body kit
- Painting bumper!!!
- !!!!!!!!!!!!!!!!!!!! Need a good painter will trade ssr mk3 !!!!!!!!!!!!!!!
- **please delete**
- clear coat dissolving new paint out! help
- Laying carbon Fiber
- can i remove spray paint off unsanded hood?
- Top Secret Gold Paint Code
- quarter panel rust?
- Any issue with using the car's body to dissipate heat?
- thought some of you guys might find this cool
- Removing paint on interior panels...
- cf clearcoat?
- rustoleum paint jobs
- SACRAMENTO area carbon fiber fiberglass
- Paint Chipping...Why?
- pics of military green ef needed
- Can anyone in So Cal Hook it up w/ powdercoating wheels?
- Process on plastic repair?
- A fiberglassed dash anyone?!?! over 25 pics!!
- DIY EK side maker made easier
- Paint, Rust Issue..
- painting my car myself..wish me luck
- Where to learn paint and body??
- Ppg envirobase
- Favorite color on an eg?
- Primer Questions
- Broken passenger side door handle: Eg hatch
- Second Project Car
- Olive green colors
- White Wheel Guys - Take Care
- paint compressor minimum psi
- Buffing/Polishing Question
- is there a way to fix this?
- Foam for custom body work?
- Home powder coating system
- lip
- Paint my ride
- Need help finding a web site for 3D cars
- Front Fender Rust Fix
- About sanding machine??
- oem replica bumper
- ...should i primer my car b-4 new paint?
- Psi?
- Buying an air compressor
- before and after Maaco paintjob
- What primers u guys using?
- Painting a engine bay
- paint shops in Sacramento CA
- need help on finding a nice gold color too paint Car...
- carbon fiber fade??
- my ej1 bay shave
- Ferio Wing
- 4th Generation prelude question Need someone SMART :)
- where can I get some dry ice?
- Please help asap!
- Is this pearl or metallic?
- Q's on painting a motorcycle/abs plastic
- Painters in wisconsin
- Quarter Panel Rust (how hard to fix it?)
- Question about Duplicolor interior vinyl paint
- Have anyone ever tried this method for dent repair?
- Phantom Grey Pearl
- need bigtime advice frame rail.
- What is the best way to remove clear coat?
- Painting type r front lip
- my clean crx is clean no more :(
- setting my garage up as a booth??
- Fender bender hit&run photos
- name the colour.
- Does anyone know of a tint-film that is safe for plastics?
- can anyone help with body work..?
- accident yesterday =[
- Does powdercoating brake calipers cause them to "trap" heat?
- EG window visors help
- Powder coating brake calipers
- Popping out a dent
- Hood question-Help!
- Advice for fixing dent
- A few pics of my car before it get painted tomm.
- pic requests
- Changing QP's on a 94 TEG. PICS
- Looking for a place to get quarters
- Car Wax, etc. frozen! Any good??
- Stripping powdercoat off of wheels
- What color is this?
- kandy basecoat over what?
- fixing crack in my bumper
- ek front bumper conversion question.
- Pinstripe
- Workin on the BodyWorks!!!
- How much paint for a Civic?
- whats the nicest black paint
- Dry ice/Hair dryer and CO2 dent removal
- front subframe is outa wack any way to whack it back?
- ef side moldings for my hatch
- milano red and roma red
- DIY or Maaco paintjob?
- need some help
- Refinishing after $50 paint job *bad idea*
- body work???
- Matching candy powdercoat with paint? how?
- carbon fiber question??? HELP!!!!
- prepping for new paint
- Doing the 50 paint job and have a question
- Got my Del Sol painted/wax???
- paint chopped. how do i prepp to fix it? sand all? or flake all?
- respraying
- Methods for Stripping this Paint??
- Help ME! How do i paint the plastic
- need help on picking a shop too paint my car??
- let's see some home made spray booths!!!
- TREMCLAD paint tips?
- claybar bad for clear coat??
- Valve Cover Question
- Fresh paint Question!
- Body work questions
- Help with satin paint job
- Dyeing carpet?
- Damaged 95 dx coupe
- another fabric paint/dye question
- Flat blue rattle can?
- What is the color code for this color?
- Rim colors?
- My 95 Civic Si Paint Thread
- Waterbase Painters, Please read!
- 1992 civic hatchback mirrors
- Front end conversion
- paint gun & compressor combos
- Transparent Spark Plug Cover
- I want this bumper...
- Powder Coating Oven
- A few questions on painting my EG...
- removing bumper paint?
- blending clear coat??
- Where to buy paint.
- EG;Taking off Paint
- primer to base, how long?
- Body Work in San Diego
- Started to prep my car for body work and paint...found this.
- Macco paint shop good or bad
- need info on this paint .
- Pic request of shades of green before paint...
- Body work va beach
- Body work or not???
- I need a paintjob in baltimore area
- How do I fix this clear coat peel?
- Bubbly grille
- Random paint question about Civics...
- $450 for two bymper Frnt and rear oem. SB collison,
- Front half-nose mask okay on new paint?
- what color should i paint my coupe
- need help what color code
- Post all DIY Paint Booths....Paint Booth Development thread!
- Anybody know that this is?
- Need opinion on body work
- How much paint for painting one car?
- paint job?? need help
- dupli anodizer?
- what color pearl?
- Windshield wiper arms help
- OEM honda Blacks?? Or any shade of black for that matter.
- spraying single stage pearl
- Recently got a paintjob - Quick Question
- Complete paint nub, would appreciate the help.
- step by step polish??
- paint question??
- EDM rear fog light help
- Aftermarket sunroof problem...
- J's Racing teal color, ppg paint code?
- OEM Spray Can
- [PIC REQUEST] 96+ Civic coupes
- I have bare metal showing from accident. Best sealant?
- Need Body work tutorial
- help me with the paintcode
- Door skin replacement
- Painting equipment
- looking for carbonfiber hood
- 89 CRX Sunroof Repair???
- Double sided tape?
- trying to find a paint job i seen other day..
- CTR yellow paint code
- How do I get access to the space in front of the radiator?
- help asap
- Paint Shop Recommendation in OC
- Looking 4 artic blue rsx side skirts
- Body shop recomndtion in san diego.
- waxing car every week
- Does macco do good paint/body work?
- need help identifying paint codes.
- Has anyone used these wheel well patch panels
