PDA
View Full Version : Paint and Body
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Frozen door seal caused broken door handle
  2. JDM Domani Front Lip..
  3. Bumper work and questions
  4. Body work help?
  5. How to: fix yellow peeling carbon fiber.
  6. front bumper
  7. Need help with 92 prelude head light assembly clearance.
  8. Repairing body damage
  9. Removing a bad paint job
  10. cheaper paint?
  11. best place to have pressure regulator and filters? harbor freight?
  12. Quality carbon fiber hoods for 96-98 Civics that DO NOT use hood pins?
  13. Dan's 1990 EF Sedan Build
  14. bumper grafting? need diy
  15. Can I Customized A California License Plate - Paint
  16. patches after paint job
  17. 95 Del Sol Radiator support replacement
  18. Paint for Silver Steel Wheels
  19. OEM lip attachment hardware
  20. How can I repair this body damage
  21. Plastic dip GSR blades question about center cap
  22. Crack in my Spoon spoiler
  23. Rust - is it bad?
  24. best place to find oem paint
  25. what brand and color powder coat for OEM look
  26. brake calipers
  27. 98 Civic Hatchback Rust Question
  28. What could i expect to pay for this quarter repair(dc2)?
  29. Painting my trans
  30. Hydro Graphics Anyone?
  31. wax and grease remover over metal prep and etch?
  32. 95 Honda Civic Paint Peeling- How to Fix it?
  33. Engine Bay Painting
  34. What is the best way to copy a trim piece?
  35. fiberglass 3 piece front Help
  36. MAACO 50% OFF DEAL. GOOD OR BAD?
  37. 2000 civic si oem paint code?
  38. 2001 Accord EX Front Bumper Cover Removal???
  39. Front Bumper Covers
  40. what are you guys using to clean your blocks??
  41. What color white?
  42. hatchback quarter glass mask or replace?
  43. I need this paint code
  44. best primer
  45. what primer color to use for GY15P
  46. Repairing CF hood
  47. Replacement quarter ?
  48. Side sill panel removal Accord -92
  49. 1999 Honda CRV - How to check for bent frame ?
  50. is there anything better than SEM vinyl dye?
  51. Wheel refinish.. What about center caps?
  52. how much paint do I need??
  53. Fiberglass repairs?
  54. Plastic Dip + Paint question
  55. Recommend good HVLP spray gun $100ish?
  56. undercarriage damage repair help!
  57. '93 Accord 4DR LX - Headliner Removal Help
  58. re clear carbon fiber
  59. How to make these rims look new again?
  60. VHT Red Wrinkle Paint Issues
  61. ENGINE BAY PAINT JOB, HELp!!!
  62. RGB to car paint...
  63. tips on how to spray paint a car
  64. 03 civic driver door - price?
  65. Proper fix for severe paint fading?
  66. Need help with body molding, 94 Coupe
  67. window trim belt molding clips removal 1992 civic
  68. Best way to remove clear coat?
  69. overspray removal on rubber window seal
  70. 94 Civic EX Clear Coat lifting on Car Roof
  71. EJ1 OEM sideskirt options.
  72. License plate garnish removal for an EJ1.
  73. Thoughts/Opinions on HF Spray Guns?
  74. Applying tiger seal to edge of wheel arch lip
  75. Advice on Painting Factory Side Skirts
  76. How soon should a door dent be hammered out?
  77. Q about clear coat......
  78. Plastic headlights.
  79. Looking for advice on painting my car from home
  80. Looking for advice
  81. CLEANING CAR UNDERBODY & UNDERCOATING
  82. Spray paint primer?
  83. interior dye?
  84. Chip Guard/Undercoat questions
  85. Possible windshield leak?
  86. OEM Red Honda Emblems for EF Civic 3DR?
  87. Can a car with oxidation be vinyl wrapped?
  88. Older recaro seat, can you help identify?
  89. ** Prep specifically for Certi-fit bumper covers?
  90. Carbon Fiber skinning
  91. Bondo on my eg quarter panel???
  92. dash paint
  93. how good is plastidip?
  94. Help me with plasti dipping rims.
  95. Remove all clear coat?
  96. proper vinyl spray paint?
  97. Milano red or New Formula for del Sol
  98. Repairing a deep scratch
  99. Painting my wheel inserts
  100. EM1 Grill / Molding Installation
  101. Re-skinning the roof on my CRX, anyone have experience with this?
  102. POWDER COATING BRAKE CALIPERS
  103. fender paint issue
  104. Budget Brand Discussion
  105. Recommendations?
  106. Painting door jams
  107. Where to get Clips for jdm side moldings
  108. what textured paint/liner to use on tow-dolly?
  109. Is this bumper sag? BB6 Lude
  110. Recommend a good body shop in Pittsburgh?
  111. Can I re-clear my entire car
  112. Valve Cover Colors
  113. Replica type r lip problem
  114. Anyone use 3M carbon fiber "vinyl" or dip parts?
  115. DIY: Headlight Restoration using Clear Coat
  116. Del Sol Stock Grille missing
  117. sticker
  118. Whats wrong with my hood alightment??
  119. Paint Help
  120. 99-00 coupe paint color
  121. Color type?
  122. CRX body
  123. CRX body work
  124. my paint job
  125. Auto to manual swap shifter cable hole.
  126. prepping for paint
  127. 1991 Civic Si, have some rust and denting, needs paint, give me your estimate
  128. earlex ok to paint a car
  129. Wet sanded through base coat...
  130. Rocker Trim Interchange
  131. CRX logo vector art
  132. it looks dumb but it works. i need help figuring the best way to golf ball my car
  133. Anyone know any good collision repair and body shops in Orlando, FL?
  134. 95 Acura Integra Floor pan
  135. Any custom body shops in Wisconsin?
  136. I got tboned!! Is my car repairable?
  137. 90's Honda
  138. anyone use color-matched aerosol spraycans from sherman-williams or english color?
  139. Rear Bumper
  140. 2006 Accord EX 4DR 4CYL Frame Dimensions
  141. How to make sharp/clean oem looking rear fender lines with filler
  142. project save a HOnda
  143. paint problems cracking after basecoat NEED HELP
  144. gun and compressor recomendations for a $600 budget
  145. tail light lens removal
  146. Question about 96 Civic windshield molding
  147. Fading & Sun damage?
  148. Type R spoiler
  149. PLEASE HELP! Scraped the bumper of my brand new 2014 civic!! :'(
  150. Which type of thinners for rustoleum or hammerite paint?
  151. What wing is this?
  152. Another rusty quarter panel question!
  153. 94 hatch, new quarters
  154. going to paint my car soon
  155. 2005 Civic rear quarter panel damage, thoughts?
  156. Paint fade on roof & hood, What would need to be done?
  157. 1991 accord DX two door rear wheel arch panels
  158. How can i fix this my bumper
  159. Are Civic and Integra Body Parts interchangeable?
  160. Touching up bits on my car?
  161. Fenders rolled?
  162. Can paint expire?
  163. where to but oem body parts
  164. How do I remove scuffs?
  165. EM1 Grill Problem
  166. Painting my EJ1, need some color ideas guys help me out
  167. how to mask/cut/peel/paint, the professional way
  168. Window Trim Fix?
  169. 400$ Paint Job?
  170. White Civics!
  171. Have any of you guys dipped your car?
  172. suggestions.. bent core?
  173. Why does my body work go to hell so fast, bubbles, rust returns
  174. bumper painting prime or not
  175. help needed with engine bay color
  176. help restoring paint '94 accord
  177. Body filler questions.
  178. Any tips on laying Napa's crossfire paint
  179. Tryed spray canning my car up, effd it up, so getting $1000 paintjob
  180. carbon fiber hood repair?
  181. Gosh... it hurts!!
  182. does anyone know this code colour
  183. DIY complete body resto-mod of my 95 Prelude
  184. Filler for Caliper? What to use?
  185. Fender Ties?
  186. PWJDM battery mount
  187. Offset Stripe on an EJ6?
  188. Hiro replica?
  189. white crow replica
  190. Shaving an engine bay
  191. What is the color of this car?
  192. Paint Suggestions
  193. Recommended Shops in Houston, Tx for body work???
  194. In need of a cheap paint job
  195. Radiator Support for '97 Integra
  196. Paint problem with 2009 honda pilot Touring Nimbus Grey
  197. authentic white crow bumper
  198. shaving out roof molding
  199. affordable roof rack
  200. How a Blue Demon is made...(PICTURE HEAVY)
  201. Re-paint and body work costs 2002 accord
  202. INFO RE: USDM GRILL PAINTING
  203. single stage urethane question
  204. Front Damage Help!!
  205. Front bumper trouble
  206. Battery Tray
  207. EJ8 Front clip question
  208. sticker bomb
  209. Need Some paint help..
  210. How to repair this little paint chip on rear bumper
  211. Color change on plastic interior parts
  212. Evaluate this rust, seems minor
  213. 2004 black on black accord w/ body issues
  214. My Rustoleum paint job Eg Sedan
  215. Body damage repair question
  216. using plastidip as a primer...question
  217. Bumper swap 94 accord lx
  218. Body Shop in the 626
  219. 05 Civic frontend damage
  220. How do I fix this?
  221. 2004 Civic rear-ended....will they fix it?
  222. Front end problems
  223. Getting a paintjob tinting ?
  224. bumper removal
  225. Honda EG Carbon Fiber Hood
  226. civic eg: What is that small black tab called?
  227. getting rid of rust
  228. Please help, rust on my DA!
  229. cracked paint. help!
  230. Need help with colormatching
  231. Rustoleum paint question
  232. how to primer a car?
  233. Custom Carbon fiber 2009 Lexus IS 250 lip
  234. should i use colormatched spraypaint to paint car or get painted somewhere cheap?
  235. $675 for rear quarter panel
  236. Removing entire quarter panels
  237. who sells engine paint with a big selection of colors ?
  238. SI rim renewal
  239. Interior Painting, can it be done to last?
  240. 94 civic hatch eg rust repair
  241. Powder coating an intake manifold?
  242. Door Skin
  243. Can I save my paint?
  244. Front grill fun time!
  245. duplicolor paint shop clear coat
  246. 97 civic sedan undercarriage
  247. Ebay Primed Fender
  248. Paint restoration over long period
  249. Setting up a garage for painting: Lighting?
  250. 2006 ridgeline hood will not open in sub zero temps.
