PDA
View Full Version : Paint and Body
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Body shop near Dayton, Ohio
  2. Color identification HELP!
  3. where can i buy champ white paint? need answer!!
  4. does anyone know what yellow this is?
  5. Need Advice for Replacement Fenders
  6. What's the best way to paint yourself with fluorescent body paint?
  7. Digital camo valve cover
  8. Need some advice on EH body work.
  9. Body gaps
  10. refinishing with the same color.
  11. removing paint from OEM civic(eg) ex lip
  12. removing horrible primer job
  13. looking for a good reputable online shop
  14. Cutting and Buffing steps involved.
  15. Dc2 carbon fiber hatch
  16. carbon fiber restoration
  17. Choosing a bright white paint code
  18. Which R81 milano red is the si one?
  19. corrosion
  20. DIY CARBON FIBER PAINT JOB
  21. Backyard 1/4 Replacement.What to do..
  22. Where to find DB8/DB7 Doors?
  23. Paint shops in the northeast
  24. recomendation for good paint shop
  25. eh2 front end swap??
  26. How difficult would this be to repair? (96-00 Civic coupe)
  27. hood color
  28. EDM .............?
  29. can i revert my painted headlight housing?
  30. What to use to clean winter salt and grit off headlights
  31. How to remove molded fiberglass/body kit?
  32. Painting my wheels flat black.
  33. Restoring these ugly headlights on my db8
  34. civic color code
  35. ef sedan in si blue?
  36. HELP: Restoring OEM lip and bumper - Filler to use?
  37. HELP: Restoring OEM front Lip and OEM Rear Bumper
  38. Painted gsr blades, want to take off the color.
  39. Clearcoat is disappearing... !
  40. Want to primer n paint my car. What do i need?
  41. How much do you think this would cost
  42. carbon fiber hood help
  43. 1100 just getting my door repainted??
  44. DIY on replacing floor pans?
  45. VC paint ideas
  46. Roof cap crx ed9/e8
  47. how much would this repair cost?
  48. good paint shops?
  49. how come there are mutilple shades for 1 paint code?
  50. Quality Paint Job Shops Sacramento Area
  51. Paint For EF
  52. What paint should i use to paint my motor?
  53. having some issues with putting primer on( paint bubbles up)
  54. Planning on Painting 1997 Honda civic..what do I need?
  55. eg hatch door?
  56. forest green pearl and clover green pearl same thing?
  57. Engine bay help
  58. replacing frame ek
  59. painting wheels
  60. How to prep a 00 civic si for a paint job?
  61. filling emblem holes
  62. Question on refurbishing stock wheels
  63. my first hatchback 95
  64. CTR wing color satin black or midori?
  65. ITR paint code wheels
  66. Having body repair done. To fill or not to fill? ?
  67. painting in the winter?
  68. dose anyone know where i can get Tahitian Green paint ?
  69. fixing cracked front bumper?
  70. paint code?
  71. How to strip blox lcas???
  72. two question. any help is good, can a damaged windshield frame be fixed, & prime>
  73. Might be buying a Shell what to look for ?
  74. How many quarts of pain do i need for my 96 civic dx coupe?
  75. what would be the best sander to prep your car
  76. 99 civic si paint
  77. Painting the fender
  78. Quarter Panel replacement
  79. Itr sides on civic
  80. Good paint for door jambs?
  81. Best paint for the money.
  82. door wegded after keys were locked in now doors not flush. Fixes?
  83. Anyone familar with PPG DBC (Deltron 2000)??
  84. NJ aouto body shops
  85. body mold
  86. Bodywork in my Basement
  87. WTB
  88. anyone use a rust converter before? luck with it?
  89. CF hood: slam or press?
  90. Help: EG Civic Window Beading Trim
  91. Removing scratches from... glass :(
  92. Auto airbrush paint work
  93. EG civic chassis ideas
  94. Lower Quarter Panel
  95. Please look, need advice on eg cx rust
  96. What color?
  97. Advice on approach for getting my 95 Si painted
  98. Polishing compound
  99. Color code question..
  100. Honda Fit : Need help- door sticking out a little bit
  101. Paint for calipers/valve cover?
  102. Best Way to Fix a Faded Roof
  103. very cool 8 minute paint job
  104. Honda Civic front bumper installation
  105. where can i go buy paint at
  106. KeeleDesign art: painted 4 wheeler
  107. DC2 - Can this rear end part be replaced?
  108. rear quarter pannel question
  109. Removing emblem adhesive
  110. Flat clear coat paint?
  111. Painted block/Trans
  112. rust repair panels
  113. 95 Del Sol - Sagging rear bumper...
  114. What's my next step after removing sealer....?
  115. how much for a stage 1 paint??
  116. eg coupe built, now to rebuild
  117. Is there a DIY for fender flaring/ wide body
  118. can a brake booster be painted or powder coated?
  119. Trying to calculate amount of paint needed to do project
  120. em1 paint question
  121. how should i paint my eg =[
  122. Cleaning surface before painting?
  123. Made it look better...
  124. hood fading problem
  125. respraying front bumper
  126. hydro dipping.
  127. They dont make a bumper for my car... lets make one!! (non-honda)
  128. Help find PPG dealer/distributor.
  129. maaco?
  130. transmission
  131. Possible to restore damaged rubber trim?
  132. Clear bra installers in NJ
  133. POLL : What color should i paint my EJ1?
  134. First time bumper painting - need help with supplies
  135. CRX: Undo painted moldings / black trim?
  136. Need help: Paint stripper safe for plastic?
  137. Dirt under primer. What to do
  138. Powder Coating gun - what's a good brand?
  139. Black paint what one to choose?
  140. Replacing Paint
  141. Can you get a real paintjob over rattlecan paint?
  142. Any1 know...!? (96-00 Civic Sedan)
  143. sectioned painting
  144. Door Pounding Questions
  145. How to wet sand / prepare for paint
  146. Carbon Fiber good or bad if you are in a crash?
  147. Clear over OEM paint?
  148. mixed opinions..what filler should I use?
  149. Painting bumper
  150. small door and quarter panel scratches. both separate...
  151. Full Lip Kit. Opinions needed.
  152. Paint code
  153. compressor size
  154. flat silver
  155. quick body filler adheasion question
  156. Lets talk about paint guns
  157. Overspray on Seat Belts
  158. How much would it cost to repaint my entire 99 Si?
  159. so i'm painting a lip and..
  160. Civic 92-95 bulk head pics needed..
  161. Paint in rattle can
  162. Difference between 4dr fender & 2dr fender
  163. Rust repair on 94 Civic Hatch: Where to cut along for replacement part?
  164. Dent below Door right next to fender
  165. wood grain steering wheel stain
  166. SOCAL only carbonfiber hood fix shops?
  167. So my car looks like shit...
  168. Rust Removal?
  169. Odyessey Rear End damage, value loss
  170. EG bumper with EK holes?
  171. HOW TO: Paint The Interior Parts of Your Car
  172. Looking for carpet!
  173. Laguna Seca Blue or Electron Blue Pearl?
  174. Color Code
  175. ROMA VS MILANO RED
  176. rust repair
  177. Quality paint shops in South Bay (SoCal) area
  178. del sol civic front swap
  179. eg mugen lip? refinish or not?
  180. chrome removal
  181. Paint supplies?
  182. Need help choosing paint materials
  183. need him on paint and primer
  184. color chart?
  185. Paint Steelies?
  186. Clearcoat seems realllly sensitive
  187. e-coat ?'s
  188. opinions welcome
  189. how to remove spray paint, paint job off my car
  190. EM1 Lip on EK Hatch?
  191. Lets talk Paint Guns!!!
  192. Repainting spokes, will it be a diff shade?
  193. Chipping bondo - price estimate?
  194. re painting the coupe
  195. Front end conversion
  196. any tips/steps for bondoing? suggestions?
  197. shaving rain rails...
  198. Side Marker Install Help in DC/MD/VA.
  199. welding holes & light filler work
  200. carbon fiber hood scoop cover?
  201. midori slight oxidizing. possivle temp fix?
  202. thinking about the $50 paint job
  203. Maaco Auto Painting & Bodyworks in Plano TX
  204. Maaco Paint Questions
  205. 99/00 si front and rear lip
  206. Good body shops in Clarksville TN
  207. pb-74p-4 paint code
  208. Mechanized Paint Removal - Power Washer, Media Blaster, Etc (Questions)
  209. Midori Paint (GY-16P) - What to tell painter?
  210. DIY reverse electrolysis...kill rust
  211. Carbon Fiber Hood repair
  212. Budget Paint Job for Car and Wheels
  213. BROKEN SIDE MIRROR hELP!!!
  214. Help with paint identification
  215. cant get paint off interior plastics
  216. Signature Shells?
  217. I need help,,mixing 100 parts to 2 parts
  218. Rustproofing/Undercoating
  219. i need primer or not?
  220. need a better paint striper
  221. MAACO?
  222. Quarter panel replacement
  223. Poly OEM replacements?
  224. Can I paint my carpet?
  225. Acryllic tops
  226. Green Integra, but what shade?
  227. engine bay help
  228. bondo on 99 si question
  229. What color is this..
  230. **HELP!! Which color black should i paint my Integra!?!?**
  231. ACURA parts
  232. 97 Accord Front Bumper
  233. trade 52' tv for paint???
  234. Before and After
  235. 97 civic to 99 civic si conversion
  236. How to rust?
  237. When your motor says hi to your hood numerous times
  238. Questions about getting my civic painted
  239. Time for a fresh coat. Please Help.
  240. sick paint job for 92-95 civic
  241. painting ls mesh purple, trying to match bov color help
  242. Looking for a Shop in GA.
  243. Painting rims
  244. How many gallon air compressor??
  245. Painting my 4dr teg
  246. Accord Skirts/Rear Lip on 93 Civic Coupe
  247. How to paint a 99 civic si - Milano Red R81
  248. overspray in the interior
  249. who makes a kevlar hood for JDM front end integra
  250. color matching bike to car
