PDA
View Full Version : Paint and Body
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. How much paint would I need?
  2. replacing 1/4 panel and door
  3. paint estimate>
  4. integra db7
  5. Sanding car help??????
  6. Side molding holes fix????
  7. how would you go about fixing this?
  8. using pearl paint...
  9. How much paint?
  10. Searching for paint guns: HVLP
  11. Chassis paint and undercarriege paint ?
  12. 95 civic window rubber question
  13. what color should i go with my EF 4door?
  14. Primer or no primer???
  15. Painting chrome rims
  16. painting polyurithane?
  17. 94 EJ1 Civic Teal Grean, complete paint job or outter only ???
  18. Code Request
  19. Help-paint shop recommendations Fayetteville, NC
  20. Do you guys recommend this HVLP gun kit?
  21. how do i remove spray paint on my steelies?
  22. should i use this spraygun!?1st timer!
  23. Need help with my black paint!
  24. i got rubbing compound on my shirt? can it wash off during routine laundry?
  25. finally got her painted
  26. Smoothing my body seam sealer inside
  27. Inside and Engine bay painting
  28. pain job
  29. paint code help.
  30. Fast, Medium, or slow??
  31. help with black base
  32. White Haze on my VIS Carbon Fiber Hood! Anybody else have this?
  33. My first paint/exterior build.
  34. Is it possible to repair an OEM Spoiler?
  35. question about flashing and sanding
  36. paint
  37. New color for Integra
  38. trying to pick color for ek
  39. Where To Buy OEM Paint?
  40. Question? Which Powder Coat Color
  41. nightshades
  42. about to do first paint job EVER
  43. Price range to powdercoat wheels?
  44. How to remove spot welds?
  45. Post your single stage paints and tips
  46. PRIMER my EG6 and what paint should i go with?
  47. Has anyone used PPG DC3000 clear?
  48. Help on good body shop in NYC
  49. How to care for newly painted car
  50. Paint defect advice, help!
  51. Need paint code off a fury
  52. Lookin for a paint code.
  53. fender/hood gap
  54. wetsanding a car thats been painted for a while
  55. Who works at a powdercoat shop?
  56. rusto with flakes added
  57. How to re-finish front lip
  58. What is "self-etching primer"?
  59. help with wash and wax
  60. Need info on rolled fender and quarter panel.
  61. paint valve cover without stripping it down?
  62. Worth repairing?
  63. what sand paper?
  64. flamenco black pearl IS AVAILABLE in spray cans for CHEAP!!!!
  65. What gun do you recommend?
  66. Wrinkle black spark plug cover?
  67. Detail work to take out spiderwebs
  68. Orignal Body Parts for 1993 Hondal Del Sol
  69. Is it possible to change a A-pillar on a dc2 integra?
  70. Painting engine bay with motor still in
  71. Using "Glue" to attach replacement panels?
  72. how to remove resude from Aircraft Striper?
  73. Where can i get the roof molding clips?
  74. quarter panel replacement cost?
  75. Bodywork on OEM bumper.
  76. Light scratches Help?!?!
  77. need help with primer
  78. Color code question
  79. Pulled dent problem. Help
  80. Kandy paint the cheap/hard way. Come criticize!
  81. Side Molding?
  82. paint help
  83. buffer pads(terry cotton, microfiber, wool?)
  84. What color paint is type r valve cover??
  85. Thermo Reactive Paint
  86. EK TYPE R YELLOW
  87. under body paint
  88. Painting an EF Sedan
  89. Buy Paint
  90. what are you suggestions for me to do for very poor paint work at a shop
  91. what can i use to circle paint flaws?
  92. Camouflage paint job on a budget. advice needed
  93. Post some patch up projects.
  94. Primer
  95. shine
  96. PAINT TROUBLE!!!!!!!
  97. Sacramento area body shops
  98. painted my wheels white..i need help!
  99. Paint Jobs around the Milwaukee area?
  100. i need my supra painted
  101. Didn't mix glazing putty w/hardener.....
  102. Rust problem can happen?
  103. handling nibs and such
  104. Rusting from inside Pics inside
  105. ***93 Honda Accord, $50 Paint Job....
  106. extreme haziness, help!
  107. On going Project
  108. Plastic Welding / Bumper Shaving
  109. colour opinions
  110. Anyone from the BAY AREA willing to help me or advice with the $50 paintjob
  111. what psi should i buy for painting?
  112. what degreaser to use for engine bay
  113. painting carbon fiber / keeping the look...
  114. underbody frame rail rust?
  115. Rolling my arches...
  116. wash and polish help
  117. My first paint job
  118. Small dents and scratches
  119. Good way to drill hole to install ferio wing
  120. Pre Project checkup Help
  121. Need help with paint color/name/code..
  122. Body and paint work in Mexico (especially Tijuana) have you had any done?
  123. Need this paint code
  124. Accendently got clear on my drivers window, best way to remove?
  125. Anyone from NJ/NY area willing to help me $50 paintjob project
  126. acura convertion
  127. Another paint scraped ontop of my clear coat.
  128. F'ing PISSED!!! my pearl white tsx got keyed
  129. Side Mirror Question
  130. Rust hood help
  131. Free Dent removal tactics (Dry Ice and Dust spray)
  132. how do you fix a faded cf hood?
  133. anybody have a sunburst yellow hatch?
  134. removing paint from tail lights
  135. what bumpers fit my 92 civic hatchback?
  136. Removing Powder coat Paint & Auto Paint heat?
  137. To ppl with JDM front ends! help!!
  138. Spray Painted Hood results bad
  139. help
  140. Painting Chrome, Need Advice
  141. First paint finished
  142. Shaved side moldings..
  143. Rattle Can Engine
  144. Need Some Painting Advice
  145. Serious wheel cleaning problems
  146. How to remove paint from mouldings?
  147. emblem holes..
  148. Removing Dent in Hood
  149. Sanded through my basecoat...
  150. Good Quality Body Shop in Miami, FL
  151. fiberglass question need anwser asap
  152. Stripped seat mount bolt ek
  153. Paint help.
  154. Front end damage on Accord. Input needed.
  155. paint or vinyl
  156. how much paint do i need?
  157. HOK Rootbeer (KBC) ?'s
  158. Takata Green
  159. what the eff do i get?
  160. My EG
  161. eg body work thread (saving $1300)
  162. Valve Cover Paint Help (Best Paint?)
  163. how do i take the back bumper off my 94 integra
  164. Are there any good Body Kits?
  165. jdm front pieces
  166. Cloth seats are fading.
  167. replacement fenders/bumpers/hoods for a 92-95 civic
  168. basic body kits installation
  169. Adriatic Blue Pearl in a Can?
  170. Burnt orange
  171. Aerosol Spray Trigger
  172. question. about sanding paint and bumper
  173. what color should i go for?
  174. suggestions for undercoating and suspension
  175. oh deer god
  176. Prep for Polyurethane Lip?
  177. good paint and body shop in birmingham, alabama?
  178. any probs with this?
  179. graffiti
  180. Paint questions :D
  181. painting my circuit 8's
  182. engine paint..
  183. i need tips on painting my door handles and moldings on civic
  184. i need tips on painting my door handles and moldings on civic
  185. Can I use hardener from another resin?
  186. rust repaair panels
  187. Clearcoat Overspray...
  188. What color to go with...
  189. question on a custom hood
  190. Shaved side moldingsintegra
  191. painting side panels?
  192. Flat purple?
  193. help with color variations
  194. What gauge sheet metal for repair?
  195. is urethane strong?
  196. Nippon maziora paint
  197. 1st day of body work for my DA
  198. Removing Engine Grease from bumpers..??
  199. '95 civic bumbers
  200. help finding a thread on $50 paint job
  201. Picking a color
  202. 2000 teggy front bumper on 96 gsr
  203. Help. Wut color is this.
  204. Color choices... Single or BC/CC?
  205. Anyone know the ppg paint code for the new bmw alpine white???
  206. Anyone use this paint before.
  207. prepping for maaco paint job
  208. Painting sideskirts/process help please!
  209. Rust-Mort anybody use this?
  210. Who has used Nason catalyst primer
  211. Carbon Fiber Trunk 90-93 integra brand new
  212. 20 gal?
  213. Expanding Foam
  214. painting bumper need help
  215. Sanding
  216. Real Automotive Paint for cheap????
  217. gettin ready to paint.
  218. EF sedan bumpers
  219. Reclearing a CF hood?
  220. ATTENTION all bodywork experts. can this be pulled and straighted or cut out??
  221. Air duster and a blow dryier dent removal?
  222. pearl paint
  223. paint or decal?
  224. VSM Sedan Color?
  225. Drains in roof removal??
  226. Rattle can spray paint
  227. Duplicolor MetalEdge paint..makes anything polished look anodized!
  228. Bumper fitment, need help
  229. Who is Rockin the Pin Stripe?
  230. thinking of painting my car
  231. sanding down carbon fiber???
  232. is CF lips repairable?
  233. Repaint Sunfade?
  234. 91 honda accord lx door skins.
  235. side and bumper molding
  236. Anyone close to Charlotte that can paint Civic Front clip for me?
  237. whats the best paint? rustoleum or marine paint
  238. Looking for someone to roll my fenders..
  239. clear coat came out like shit, hazy? Opinions?
  240. How to paint match?
  241. vsm single stage paint?
  242. Seeking experienced and professional painter help
  243. polishing compound
  244. Need help with choosing the right filler for plastic parts
  245. WTB eg fenders,bumpers,hood
  246. what color should i paint lip?
  247. Flakes in rustoleum!!!!!!!
  248. i dont really understand?
  249. anyone thats painted there own car..
  250. Best CHEAP compressor to do the DIY paintjob?????
