Auto Cross Alignment
Old Jun 10, 2015 | 05:32 PM
dc296TypeR's Avatar
Default Auto Cross Alignment
Looking on doing some autocross events in my Type r and need help on a set-up.
Running Spoon N1 dampers F.16K R.14K
Damper settings ?
Potenza RE11 Air pressure ?
Alignment specs ?
Car is set-up for circuit racing in Japan.
Any help would be greatly appreciated.
Old Jun 11, 2015 | 07:17 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Auto Cross Alignment
Try doing a search. Nothing has really changed in the past 10+ years in terms of the setup questions you're asking (except tire pressure for your specific tires).
That will give you a good starting place and you can ask specifics based on that.
Old Jun 11, 2015 | 11:14 AM
dc296TypeR's Avatar
I have been looking and have some specs that I will try.
Just want to keep my car on the track.
Old Jun 12, 2015 | 02:40 PM
dc296TypeR's Avatar
Just had a alignment and no wonder I wore a set if tires in less than 8000 kms
Front
Toe left 3/8
Right 13/32
Total 3/4
Now left 1/32
Right 1/32
Total 3/32
Rear toe
Left 1/32
Right 1/16
Total 3/32
Now 0
Old Jun 13, 2015 | 01:37 PM
94eg!'s Avatar
#1 Super Guy
Loved
lol @ 3/4 total. WTF?!
Old Jun 13, 2015 | 09:47 PM
dc296TypeR's Avatar
Wore out a set of Yokohama AD08 in 10,000 kms (6000 miles)
Old Jun 15, 2015 | 10:04 AM
SlapSmak's Avatar
Here you go. A DIY I wrote a long time ago, with AutoX Specs...
https://honda-tech.com/acura-integra...ethod-2631081/
Old Jun 15, 2015 | 07:48 PM
coolhandluke's Avatar
Wowza!
OP- Those are some aggressive spring rates. If the Auto-X surfaces aren't smooth you might want to consider dialing those back. What is the rear sway bay configuration?
Old Jun 22, 2015 | 06:24 AM
dc296TypeR's Avatar
Originally Posted by coolhandluke
Wowza!
Rear sway bar is stock type r size,Set damping on 1 and worked great also played with airpressure .
Went from understeer to oversteer now feels neutral also seat time was the most helpful.
Old Jun 22, 2015 | 06:59 AM
CW-ITR's Avatar
"Set damping on 1 and worked great" <-- If "1" means the softest, that mean you are autoxing on smooth surface. Because with "F.16K R.14K" spring rates and "damping on 1" setting, your rebound rate is so low that your caR will be hopping all over the place on a rough, bouncy surface.
Old Jun 27, 2015 | 01:03 AM
dc296TypeR's Avatar
The local go-kart is very smooth.Next time I will try 2 front and 3 back.
whatcivic
11
Oct 26, 2009 10:26 AM
All-Motor-Junkie
Oct 7, 2006 04:52 PM
Flux
18
Aug 30, 2005 04:46 PM
slow91crx
Suspension & Brakes
14
May 17, 2005 03:34 PM
Jon V
Suspension & Brakes
Jan 21, 2005 04:38 AM
