Engine code 45 too rich/too lean
Old Mar 7, 2015 | 10:58 AM
97CWITR's Avatar
Default Engine code 45 too rich/too lean
Need some help from anyone who's delt with this code.
I'm getting poor mileage, occasional idle drop to 400rpms, power delivery isn't smooth.
Last thing I want to do is throw parts at it.
Anyone recommend tests to run or what could be causing it?
Some other threads suggest a fpr, o2 sensors...
I believe the sensors are fairly new but could be faulty. An oem fpr used is only $20...
Help or suggestions welcome!
Old Mar 8, 2015 | 12:37 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Engine code 45 too rich/too lean
Start with checking the if theres any check engine codes.
Check your mech timing.
If your idle drops try cleaning the IACV with brake cleaner.
Old Mar 8, 2015 | 03:52 PM
veks's Avatar
Check for codes first like mention above.
P0171 (45) is system too lean probable cause:
Fuel system
Primary HO2S (sensor 1)
Map sensor
Contaminated fuel
Valve clearance
Exhaust leakage
P0172 (45) is system too rich probable cause:
Fuel system
Map sensor
Contaminated fuel
Valve clearance
Only difference from is exhaust leak.
Old Mar 9, 2015 | 07:45 AM
boostjunkie757's Avatar
you hadnt done a compression/leakdown test before logging on honda-tech??
Old Mar 10, 2015 | 07:29 AM
97CWITR's Avatar
Fuel system
Map sensor
Contaminated fuel
Valve clearance
Exhaust leakage
Fuel system
Map sensor
Contaminated fuel
Valve clearance
Code has gone away but I'm going to adjust the valves regardless. Probably do more maintenance as well.
Old Mar 12, 2015 | 01:45 PM
97CWITR's Avatar
It was P0172 too rich.
Have it at Acura now and the fuel system is okay, same with O2 sensors.
Getting a valve adjustment next week. Will keep this thread updated so future ppl will have an idea.
How long (time wise) are timing belts good for?
Last replacement was 12 years ago but only 50,000 kms.
Old Mar 12, 2015 | 04:50 PM
veks's Avatar
It's going to be one of 3 things; evap solenoid, valve clearance or fuel injectors.
Old Mar 13, 2015 | 07:40 AM
97CWITR's Avatar
Fuel injectors were checked, valve clearance hasn't been done. How do I check the evap solenoid?
Old Mar 13, 2015 | 10:25 AM
veks's Avatar
With a vacuum pump, apply vacuum to the EVAP solenoid. If it doesn't hold vacuum replace it.
Old Mar 13, 2015 | 12:53 PM
97CWITR's Avatar
Will do, thanks!
Slacker93eg
Apr 27, 2013 08:46 AM
Hatch_kyle
Apr 14, 2012 12:33 AM
LiL JoN
Mar 1, 2010 08:41 PM
91CRXSI
Jul 16, 2002 07:42 PM
