SOS UK Spec ITR Error Code Help Help
Old May 28, 2015 | 08:45 AM
Maccattack's Avatar
Default SOS UK Spec ITR Error Code Help Help
Hi All,
Need help with ABS Light on in my UK Spec ITR 1998.
ABS light is constantly on and flash code suggests a speed sensor in the gearbox. I called Honda for a quote on the part and was told speed sensor has nothing to do with the ABS system.
And ideas, any help greatly appreciated.
Macca
Old May 28, 2015 | 09:25 AM
CW-ITR's Avatar
Default Re: SOS UK Spec ITR Error Code Help Help
Yea, they are two different things. As for the ABS light on, Jack up the caR and inspect all four ABS sensors for damage. Replace whatever necessaryand clean up all sensors. GL
Old May 28, 2015 | 11:17 AM
Maccattack's Avatar
Thanks, where are the rear sensors located. I can see the fronts but not the backs? Thanks
Old May 28, 2015 | 02:51 PM
Maccattack's Avatar
Hi Abs flash codes are. (Abs light flashing.)
1 Long followed by 7 short
1 Long followed by 8 short
8 long followed by 1 short
Can anybody help with understanding the code?
Many thanks
Old May 29, 2015 | 06:31 AM
CW-ITR's Avatar
Credit to "noahw" from "Instructable" and you you go:
"How to Read Codes From Your Check Engine Light"
With the wire in place, put the key in the ignition and put the car into the "run" position. That's two clicks for Honda users.
Wait a second and keep your eye on the check engine light. You should see it start to light up in a series of flashes.
The light is blinking in a simple code of long and short. Long blinks mean "10" and short blinks mean "1".
For example, if light was blinking once for a long time, and then twice for a short time. That is 10, 1 and 1 which means error code 12. Code 12 indicates a problem with EGR system. This is the system that sends some of the engine's exhaust into the cylinder to cool the combustion process and keep temps in the cylinders down. Having a broken EGR is relatively common on a high mileage car.
You can find a list of error codes for the make and model of your car online by doing a simple search. The ones for Honda are included below.
Honda Check Engine Light Error Codes
0 ECU
1 Oxygen Sensor
3 Map Sensor
5 Map Sensor
6 Crank Angle
7 Throttle Angle
8 TDC Position
9 No. 1 Cylinder Position
10 Intake Air Temperature
12 Exhaust Gas Reiculation (EGR) System
13 Atmospheric Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
22 Vtec System Malfunction
23 Knock Sensor
41 o2 Sensor
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated o2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary o2 Sensor Circuit
63 Secondary o2 Sensor Circuit
67 Catalyst Sytem
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
Old May 29, 2015 | 06:35 AM
CW-ITR's Avatar
Sorry, can't help you with that. LOL. Anyway, here is a good article on how to clean the sensors:
https://honda-tech.com/acura-integra...ensor-1584925/
Old May 29, 2015 | 10:11 PM
B16EJ's Avatar
I'm assuming you have taken a rear tire off, if so look at it directly from the bottom, it's covered by a small shield and a couple 10 mm bolts, very easy to find.
Maccattack
May 28, 2015 02:59 PM
mr_munro
Mar 14, 2012 11:53 AM
tjwebber17
Suspension & Brakes
Jul 2, 2011 10:15 AM
woodwardba0526
Honda Civic (2001 - 2005)
Nov 12, 2010 10:39 AM
VTECAcuraGSR
Aug 18, 2002 03:33 PM
