HELP! code p0336
Old Mar 15, 2015 | 06:18 PM
B16EJ's Avatar
Default HELP! code p0336
Hey guys, I'll start with some background info. Had my 99 itr motor rebuilt fall of 2013, sat until last spring. Ever since the rebuild its been throwing code p0336 for the crank position sensor in the distributor.
I had a tough time getting it started in the spring but after getting it running 100 kms in the head gasket blew. Got it replaced last summer and had an ac system put back in as it was taken out by previous owner. After picking it up from the mechanic it ran great, but was still throwing the code, VTEC engaged and the car ran fine so I just drove like that last summer because I just wanted to drive the car.
I built a new distributor using OEM parts over the winter, the original distributor was filling up with the "red dust of death"and was throwing the code so I thought I could fix my problems with a freshened up distributor. I started the car up today, it took allot of cranks to get it to start and every time since it's been taking a few cranks to start, not the usual kick and start, the motor isnt running perfectly smooth after start up and won't rev past 3500 rpms, and code p0336 still persists, even with a different sensors/distributor.
Lastly the only other code being thrown is the code for the secondary o2 sensor which I'm aware of because the previous owner removed that too for unknown reasons. I have a sensor and bung ready to fix that problem. I just want to tackle this issue first.
I'm lost on what to do next. Should I check for continuity in the ckp wire through the harness to the ecu? Also I'm a total noob with electronic troubleshooting as you can see by my last thread.
Old Mar 16, 2015 | 06:41 AM
94rs-turbo's Avatar
Default Re: HELP! code p0336
is the engine jdm? if so jdm swaps don't have that sensor and usdm ecu's will trip that code but I know a bypass for it
Old Mar 16, 2015 | 07:20 AM
B16EJ's Avatar
No it's the original motor in my itr, I have been reading allot about this issue and the by pass that I've heard about is in regards to the crank fluctuation sensor by the oil pump, and from what I have gathered my code is referring to the crank position sensor, in the distributor.
Were you talking about the sensor by the oil pump, or in distributor?
Old Mar 16, 2015 | 11:09 AM
veks's Avatar
I got this from my helm manual.
Old Mar 16, 2015 | 02:19 PM
B16EJ's Avatar
thanks Veks!!,
I am going to try to test the wires now thanks for the input guys I really appreciate it, I'll post up the results
Old Mar 16, 2015 | 03:57 PM
B16EJ's Avatar
How do I "measure resistance" what settings do I need to set the multi meter at and where do I put the ground probe? I pieced together that the red probe will be placed onto the terminals in question but where does the ground probe go?
Old Mar 16, 2015 | 08:06 PM
B16EJ's Avatar
Tested the distributor sensors and 2 more spare sets of distributor sensors, the 2 spare sets consist of just the wires and sensors still connected, on every sensor I got readings of .38 ohms for all three sensors or .40 on all 3 sensors, since the reasons are all the same I assume the sensors are all functioning even though the manual states 0.5 or 1.0
And for continuity I simply placed both probes on either side of the same terminal and got readings of 0.00 which from what I understand means that there is continuity.
If the way I tested is correct my results indicate that the sensors are functioning and that there is continuity, so my next step is to test the wiring at the ecu terminals, but I can't until tomorrow my car is parked in my parents garage, I removed the distributor and took it hone after work today so I could test it when I had free time.
If the way I tested is wrong can someone please explain how I'm supposed to use the multi meter?
Thanks again guys for all the help, I have already learned some valuable info which I appreciate allot.
Old Mar 17, 2015 | 12:37 PM
veks's Avatar
you might find better, good luck
Old Mar 18, 2015 | 06:28 PM
B16EJ's Avatar
Hey guys...
I haven't found the solution to my problem but I did discover something today. I took a look at the timing on my car and it's out, it's out by half a tooth, so it's impossible to get to tdc.
Could this be why I'm throwing this code? Because the timing is off? Would setting the ignition timing fix the issue of it being off?
Old Mar 19, 2015 | 06:33 AM
B16EJ's Avatar
TTT I know one of the knowledgeable people in this forum know the answer I'm getting desperate I really want to drive this damn car before I turn 35 in a cpl months lol
Old Apr 3, 2015 | 07:38 PM
B16EJ's Avatar
Well after weeks of frustration and wondering and tearing down distributors and rebuilding them, I got in touch with an old buddy that still has his 99 civic sir and I borrowed his distributor today, my car roared to life no problem after installing it, code 0336 gone.
After letting my car run for 20-30 mins I tried my distributor that wouldn't start the car yesterday, and the car started up just fine, no more code 0336, and was revving normally and past 3500 rpms.
I'm super stoked that my car is running but I'm totally stumped as to why the same distributor that wouldn't start my car yesterday started it today, after running for 30 mins with a different distributor first... Perhaps I flooded the car when trying to start it yesterday?
The car has been sitting since last October, i also remember last year in the spring the car also had a hard time starting much like this year, and I had to pull the plugs and let the car sit for a day to dry up before it finally started.
Every other Honda I have ever owned usually starts right up in the spring after sitting for the winter, I can't seem to figure out why my itr has a hard time starting up in the spring.
Regardless I'm just happy that it's running and the code is gone, thank u very much Veks for all your help, I learned allot about multi meters and how to use one, plus the helms pages you gave me was a life saver, I wouldn't know where to begin if you didn't help out, and thanks also to Chase for the input, much appreciated.
It feels like a huge weight has been lifted off my shoulders, the car has been constantly bothering me the last few weeks and it's finally over, time to drive that spoiled car of mine!
HA0LEFIED
Dec 13, 2006 04:04 AM
psycho.chicken
Jul 21, 2006 09:34 AM
GuyInASpeedo
Sep 25, 2003 07:05 PM
WesticLe
Sep 25, 2003 04:50 PM
Spade
Jul 30, 2002 02:05 PM
