Bogging issue
Old Apr 28, 2015 | 06:50 AM
shahriar35's Avatar
Default Bogging issue
Good morning all,
I'm having this bogging issue with my 2000 type R w/ a JRSC. The car was running just fine, until recently. The bogging happens often between shifts and at low speed. I cant seem to figure out what is causing it. I replaced the battery recently because the old battery was leaking and my assuming was that the build up of acid on the positive (+) terminal was causing it, but with that problem fixed, I'm still having this issue. Any thought?
Thanks
Old Apr 28, 2015 | 08:07 AM
CW-ITR's Avatar
Default Re: Bogging issue
If you are running 2 steps colder spark plugs, check for carbon build up and also double check the gapping. Double check all vac lines for tightness. GL
Old Apr 29, 2015 | 06:43 AM
shahriar35's Avatar
Thank you,
Does anyone know what the gap is suppose to be on 2 step colder spark plugs, I cant recall it or if that is what I'm running. The perks of having a JRSC, constant maintenance!
I will check everything hopefully this week.
Old Apr 30, 2015 | 09:49 AM
CW-ITR's Avatar
My is gapped at .032"
General rule is don't go too wide if you are running stock ignition or else you may have some misfire at high RPM.
Old May 5, 2015 | 08:38 AM
shahriar35's Avatar
Thank you for the assistance, I removed each spark plug and cleaned them up and re-gapped them to .032, they were a lot less. At the same time I also cleaned the IACV. One or the other or both solved the bogging issue. Thank you again
Old May 5, 2015 | 08:40 PM
CW-ITR's Avatar
You're welcome
Old May 7, 2015 | 09:48 AM
PaulMc's Avatar
Painfully Stupid
Had same issue, are you throwing a code for the knock sensor?
emooheo
Aug 18, 2007 11:27 AM
Used2beAb16
Mar 2, 2005 09:19 PM
boosted lude
Oct 10, 2004 12:23 PM
sporkcrx
Jul 3, 2004 07:59 PM
