a/c question
Old Apr 24, 2015 | 09:41 AM
JTECHDC2's Avatar
Default a/c question
In my type r the ac compressor only turns on when I ground it from the fuse box to the battery. What could be the issue? Please help.
Old Apr 28, 2015 | 10:32 AM
Tootsie7944's Avatar
Default Re: a/c question
Did you get metal to metal contact where you normally ground it? You need to sand down the metal and make sure you use a ground bolt and not a normal bolt.
Are you sure the wire harness is clipped in all the way?
Old Apr 28, 2015 | 10:54 AM
TypeRod's Avatar
I suggest checking the relay first, then any loose connections in the fuse box.
Old Apr 29, 2015 | 08:33 AM
JTECHDC2's Avatar
I have checked all connections and they are ok the only thing I have not tried is jumping the thermostat to see if that is the issue. Right now it only work if I ground it from the engine fuse to the battery straight. thanks guys.
DialedLife
Mar 31, 2019 12:07 PM
xtpking3
May 6, 2014 05:05 AM
1993gsrcivic
Apr 10, 2009 11:14 AM
HondamanXxX
16
Jun 25, 2007 07:08 PM
smash fascism
Apr 8, 2005 12:11 PM
