Door lock actuator gremlins...
Hey guys,
So last week my actuator stopped working, I figured it just needed to be replaced...
Last night it randomly started working again? Think it is still bad but just intermittently starts working?
For $40 from the stealership I will probably just replace it anyway, but I am curious.
Gracias.
Gracias.
Re: Door lock actuator gremlins...
Face it, your car hates you.
Could have a broken wire or something, who knows. Once you swap it out with the new one, conduct a failure analysis and post the results here.
lol thats weird....
well first things first if something to do with electrical check your fuse box then go to the main problem
thats what happened to my door i thought its the actuator but it turns out its just the fuse lolz
yeah its up to you but i tell you if its only your fuse not you've just wasted your plus your time and also it wont work if your fuse are burned
